Thanks Vicky.
So, my time problem is to get geometry from “roads” that make the vertex connections.
Just for fun:
Executing this 10 times alternated:
select * INTO dijkstra_results FROM pgr_dijkstra(
Query returned successfully: 1528890 rows affected, 6 to 7 seconds execution time.
Create temporary table dijkstra_results as select * from pgr_dijkstra(
Query returned successfully: 1528890 rows affected, 2 to 3 seconds execution time.
To do idea:
Some pgr function thats return and use geometry like reverse_cost, maybe has_geometry than pass to the ‘sql’, and results like cost vertex_start/vertex_end linestring, and agg_cost making final linemerge linestring…
Executing my query separatelly get same time result.
Thanks again Vicky.
2016-08-11 19:37 GMT-03:00 <pgrouting-users-request@lists.osgeo.org>:
Send Pgrouting-users mailing list submissions to
pgrouting-users@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
or, via email, send a message with subject or body ‘help’ to
pgrouting-users-request@lists.osgeo.orgYou can reach the person managing the list at
pgrouting-users-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of Pgrouting-users digest…”Today’s Topics:
- Re: PGR_DIJKSTRA execution time (Vicky Vergara)
Message: 1
Date: Thu, 11 Aug 2016 17:37:30 -0500
To: pgRouting users mailing list <pgrouting-users@lists.osgeo.org>
Subject: Re: [pgrouting-users] PGR_DIJKSTRA execution time
Message-ID:
<CAK_FzuW75U35T2jckH=E3iuAiQGYKhi2Er+kfhiBGL+m++O_jA@mail.gmail.com>
Content-Type: text/plain; charset=“utf-8”Hello Omar,
I don’t have your data (not intending to have it) so, lets go by steps:
First of all the code looks quite “crowded”, so I took the liberty of
formatting it a little, see at the bottom.If its a matter of analysis, lets start with using
\timing
so after each command you get the time it took to do thingsThe insert clause is doing many things:
- has a JOIN that takes time,
- has this ST_LineMerge(st_collect(the_geom) that also consume time
- has this array_to_string(array_agg(edge),‘,’) that also consume time
- has the call to pgr_dijkstra that also consumes time, etc.
if you want to time how long it takes to make the pgr_dijkstra just do:
SELECT * FROM pgr_dijkstra(‘SELECT id, source, target, cost, reverse_cost
FROM view_vertex’,array[3922267,3922268,3922269,3922270,3922271,3922272,3922273,3922274,3922275,3922276,3922277,3922278,
3922279,2667391,3922280,3922281,3922282,3922283,3922284,3922285,3922286,3922287,3922288,3922289,
3922290,3922291,3922292,3922293,3922294,3922295,3922296,3922297,3922298,3922299,3922300,3922301,
3922302,3922303,3922304,3922305,3922306,3922307,3922308,3922309,3922310,3922311,3922312,3922313,
3922314,3922315,3922316,3922317,3922318,3922319,3922320,3922321,3922322,3922323,3922324,3922325,
3922326,3922327,3922328,3922329,3922330,3922331,3922332,3922333,3922334,3922335,3922336,3922337,
3922338,3922339,3922340,3922341,3922342,3922343,3922344,3922345,3922346,3922347,3922348,3922349,
3922350,3922351,3922352,3922353,3922354,3922355,3922356,3922357,3922358,3922359,3922360,3922361,
3922362,3922363,3922364,3922365,3922366,3922367,3922368,3922369,3922370],
, true);you can save the results in a temporary table:
select * INTO dijkstra_results FROM pgr_dijkstra(…);
– do the insert clause using dijkstra_results
drop table dijkstra_resultsHope I was of help.
Vicky/* a little formatting */
DROP materialized view if exists view_vertex;
CREATE materialized view view_vertex as (
(select id, the_geom, vel_med,source, target, cost, reverse_cost
from vertex_ruas
where the_geom && ‘POLYGON((-49.3954855 -27.0998678,-49.3954855
-26.6055895,-48.7818607 -26.6055895,-48.7818607 -27.0998678,-49.3954855
-27.0998678))’::geometry and status <> 1)
UNION ALL
from vertex_ruas_aux
-27.0998678))’::geometry and status <> 1));CREATE UNIQUE INDEX idx_id_view_vertex ON view_vertex(id);
CREATE INDEX idx_source_view_vertex ON view_vertex(source);
CREATE INDEX idx_target_view_vertex ON view_vertex(target);insert into trajetos
select id, ids, idt, st_length(the_geom::geography) as distancia ,
sequencia, sequencia_vertex, the_geom, vel_med
from (
SELECT start_vid || ‘-’ || end_vid as id,start_vid as ids, end_vid as
idt, array_to_string(array_agg(edge),‘,’) as sequencia,
array_to_string(array_agg(node),‘,’) as
sequencia_vertex,ST_LineMerge(st_collect(the_geom)) as the_geom,
avg(vel_med) as vel_medFROM pgr_dijkstra(‘SELECT id, source, target, cost, reverse_cost FROM
, true)join view_vertex t on t.id = edge group by start_vid, end_vid order by
start_vid, end_vid) a;On Thu, Aug 11, 2016 at 1:42 PM, Omar Fernando Pessôa <omar.pessoa@gmail.com
wrote:
Hi guys.
I am using OSM to generate my road postgis database (south of Brazil).
My vertex table has 1282959 rows.
To decrease time to run PGR_DIJKSTRA I have make a box from my
“destinations” position. Decreasing it to 18264 rows in a materialized view
with indexes.Then running PGR_DIJKSTRA, with k x k (k = 100± vertex). The running
time of PGR_DIJKSTRA is something about 30s.This is a good “time”? Can I do it better?
drop materialized view if exists view_vertex;
*create materialized view view_vertex as((select id, the_geom,
vel_med,source, target, cost, reverse_cost from vertex_ruas where the_geom
&& ‘POLYGON((-49.3954855 -27.0998678,-49.3954855 -26.6055895,-48.7818607
-26.6055895,-48.7818607 -27.0998678,-49.3954855 -27.0998678))’::geometry
and status <> 1) UNION ALL(select id, the_geom, vel_med,source, target,
cost, reverse_cost from vertex_ruas_aux where the_geom &&
and status <> 1)); *
insert into trajetos select id, ids, idt, st_length(the_geom::geography)
as distancia , sequencia, sequencia_vertex, the_geom, vel_med from(SELECT
start_vid || ‘-’ || end_vid as id,start_vid as ids, end_vid as idt,
avg(vel_med) as vel_med FROM pgr_dijkstra( ‘SELECT id, source, target,
cost, reverse_cost FROM view_vertex’ ,
array[3922267,3922268,3922269,3922270,3922271,3922272,3922273,3922274,3922275,3922276,3922277,3922278,3922279,2667391,3922280,3922281,3922282,3922283,3922284,3922285,3922286,3922287,3922288,3922289,3922290,3922291,3922292,3922293,3922294,3922295,3922296,3922297,3922298,3922299,3922300,3922301,3922302,3922303,3922304,3922305,3922306,3922307,3922308,3922309,3922310,3922311,3922312,3922313,3922314,3922315,3922316,3922317,3922318,3922319,3922320,3922321,3922322,3922323,3922324,3922325,3922326,3922327,3922328,3922329,3922330,3922331,3922332,3922333,3922334,3922335,3922336,3922337,3922338,3922339,3922340,3922341,3922342,3922343,3922344,3922345,3922346,3922347,3922348,3922349,3922350,3922351,3922352,3922353,3922354,3922355,3922356,3922357,3922358,3922359,3922360,3922361,3922362,3922363,3922364,3922365,3922366,3922367,3922368,3922369,3922370],
true)join view_vertex t on t.id <http://t.id> = edge group by start_vid,
end_vid order by start_vid, end_vid)a;‘’’
This is my way to do this. (example).
Thanks guys! Waiting for withpoints to make me happy. This *vertex_ruas_aux
*table is a helper table to create new vertex using *ST_LineLocatePoint *from
*vertex_ruas, *status is set to 1 to make this invalid, generating 2 new
linestrings vertex_ruas_aux.
http://www.opessoa.com
Desenvolvedor de Sistemas / Systems Software Developer
C++ / PHP / C# / Javascript
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users–
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, GermanyVicky Vergara
Operations ResearcheMail: vicky@georepublic.de
Web: https://georepublic.infoTel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
An HTML attachment was scrubbed…
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160811/d4da0913/attachment.html>
Subject: Digest Footer
End of Pgrouting-users Digest, Vol 94, Issue 3
