Hi guys,
I'm playing with pgrouting workshop of FOSS4G 2011.
There is any link to download the workshop material?
Thanks
Pedro
Hi guys,
Thanks
Pedro
Hi Pedro,
The years before it was always available on OSGeo server: http://download.osgeo.org/pgrouting/foss4g2010/
It seems I forgot to place the 2011 workshop there as well.
The workshop documentation source is on Github: https://github.com/pgRouting/workshop
So all you’re missing is the sample data. But you can download any OSM data or even use the sample data of 2010.
In case you’re using Ubuntu/Debian you can install last years workshop as a package easily:
https://launchpad.net/~georepublic/+archive/pgrouting/+packages
It contains the sample data of Denver as well. Or you download the tarball [1] and extract it.
Or, you use OSGeo Live DVD. It contains the workshop as well:
http://live.osgeo.org/en/quickstart/pgrouting_quickstart.html (see “What’s next” at the end of the page).
Hope that helps,
Daniel
[1] https://launchpad.net/~georepublic/+archive/pgrouting/+files/pgrouting%2Bworkshop_0.6.1.orig.tar.gz
On Tue, Jul 10, 2012 at 10:15 AM, Pedro Costa <pedrocostaarma@sapo.pt> wrote:
Hi guys,
I’m playing with pgrouting workshop of FOSS4G 2011.
There is any link to download the workshop material?Thanks
Pedro
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Hi Daniel,
thanks for your help
Em 10-07-2012 09:33, Daniel Kastl escreveu:
Hi Pedro,
It seems I forgot to place the 2011 workshop there as well.The workshop documentation source is on Github: https://github.com/pgRouting/workshop
So all you're missing is the sample data. But you can download any OSM data or even use the sample data of 2010.In case you're using Ubuntu/Debian you can install last years workshop as a package easily:
https://launchpad.net/~georepublic/+archive/pgrouting/+packages <https://launchpad.net/~georepublic/+archive/pgrouting/+packages>
It contains the sample data of Denver as well. Or you download the tarball [1] and extract it.Or, you use OSGeo Live DVD. It contains the workshop as well:
http://live.osgeo.org/en/quickstart/pgrouting_quickstart.html (see "What's next" at the end of the page).Hope that helps,
Daniel[1] https://launchpad.net/~georepublic/+archive/pgrouting/+files/pgrouting%2Bworkshop_0.6.1.orig.tar.gz <https://launchpad.net/~georepublic/+archive/pgrouting/+files/pgrouting%2Bworkshop_0.6.1.orig.tar.gz>
On Tue, Jul 10, 2012 at 10:15 AM, Pedro Costa <pedrocostaarma@sapo.pt <mailto:pedrocostaarma@sapo.pt>> wrote:
Hi guys,
Pedro
<mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-users--
eMail: daniel.kastl@georepublic.de <mailto:daniel.kastl@georepublic.de>
Web: http://georepublic.de/>_______________________________________________
I'm trying to adapt this function (findnearestedge) [1] to my routing data that are in srs 27492.
Someone can help me with that?
thanks
[1]
$startEdge = findNearestEdge($startPoint);
$endEdge = findNearestEdge($endPoint);
function findNearestEdge($lonlat) {
SELECT gid, source, target, the_geom,
distance(the_geom, GeometryFromText(
'POINT(".$lonlat[0]." ".$lonlat[1].")', 4326)) AS dist
FROM ".TABLE."
WHERE the_geom && setsrid(
'BOX3D(".($lonlat[0]-0.1)."
".($lonlat[1]-0.1).",
".($lonlat[0]+0.1)."
".($lonlat[1]+0.1).")'::box3d, 4326)
ORDER BY dist LIMIT 1"
Hi Pedro,
Hi guys,
Pedro
Hi Pedro,
In which projection are your start and end point?You need to use ST_transform(,) if the projection is different.
In the workshop the data is in 4326 (WGS84) and so you can find this SRID in the SQL statement.
Daniel
On Tue, Jul 10, 2012 at 11:42 AM, Pedro Costa <pedrocostaarma@sapo.pt> wrote:
I’m trying to adapt this function (findnearestedge) [1] to my routing data that are in srs 27492.
thanks
[1]
$endEdge = findNearestEdge($endPoint);function findNearestEdge($lonlat) {
‘POINT(“.$lonlat[0].” “.$lonlat[1].”)’, 4326)) AS dist
FROM “.TABLE.”
‘BOX3D(“.($lonlat[0]-0.1).”
“.($lonlat[1]-0.1).”,
“.($lonlat[0]+0.1).”
“.($lonlat[1]+0.1).”)’::box3d, 4326)
ORDER BY dist LIMIT 1"Em 10-07-2012 09:33, Daniel Kastl escreveu:
Hi Pedro,
So all you’re missing is the sample data. But you can download any OSM data or even use the sample data of 2010.In case you’re using Ubuntu/Debian you can install last years workshop as a package easily:
http://live.osgeo.org/en/quickstart/pgrouting_quickstart.html (see “What’s next” at the end of the page).Hope that helps,
Hi guys,
Pedro
http://lists.osgeo.org/mailman/listinfo/pgrouting-users–
Web: http://georepublic.de_______________________________________________ Pgrouting-users mailing list [Pgrouting-users@lists.osgeo.org](mailto:Pgrouting-users@lists.osgeo.org) [http://lists.osgeo.org/mailman/listinfo/pgrouting-users](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)
I'm confused.
My map is in srs 900913 and my tables in postgis are in srs 27492.
In workshop example the points are converted to srs 4326 why?
Because the funcion findnearestedge needs the data in srs 4326?
If yes, i just need to convert to my table srs (900913) correct?
Thanks
[1] var startpoint = layer.features[0].geometry.clone();
startpoint.transform(epsg_900913, epsg_4326);
var finalpoint = layer.features[1].geometry.clone();
finalpoint.transform(epsg_900913, epsg_4326);
Em 10-07-2012 11:09, Daniel Kastl escreveu:
Hi Pedro,
You need to use ST_transform(<geom>,<srid>) if the projection is different.
In the workshop the data is in 4326 (WGS84) and so you can find this SRID in the SQL statement.Daniel
On Tue, Jul 10, 2012 at 11:42 AM, Pedro Costa <pedrocostaarma@sapo.pt <mailto:pedrocostaarma@sapo.pt>> wrote:
routing data that are in srs 27492.Someone can help me with that?
thanks
[1]
4326)) AS dist
FROM ".TABLE."
Hi Pedro,
Daniel[1]
<https://launchpad.net/~georepublic/+archive/pgrouting/+files/pgrouting%2Bworkshop_0.6.1.orig.tar.gz>On Tue, Jul 10, 2012 at 10:15 AM, Pedro Costa
<pedrocostaarma@sapo.pt <mailto:pedrocostaarma@sapo.pt>> wrote:Hi guys,
Pedro
http://lists.osgeo.org/mailman/listinfo/pgrouting-users-- Georepublic UG & Georepublic Japan
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-users_______________________________________________
On Tue, Jul 10, 2012 at 12:47 PM, Pedro Costa <pedrocostaarma@sapo.pt> wrote:
I’m confused.
My map is in srs 900913 and my tables in postgis are in srs 27492.In workshop example the points are converted to srs 4326 why?
Hi Pedro,
OSM data imported with osm2pgrouting or osm2po are WGS84 (4326), so this is what you have in the database.
OpenLayers uses World Mercator projection (900913 and there are some aliases), so start point and end point in the workshop need to be transformed to 4326.
In your case you had to replace 4326 with 27492, I guess, assuming that you use OpenLayers (GeoExt) and your dataset.
Daniel
Thanks
finalpoint.transform(epsg_900913, epsg_4326);Em 10-07-2012 11:09, Daniel Kastl escreveu:
Hi Pedro,
thanks
[1]
FROM “.TABLE.”
Hi Pedro,
Hi guys,
Pedro
Thanks again Daniel.
Now i'm trying everything but i get this error in firebug:
"NetworkError: 500 Internal Server Error - http://mydomain.pt/routing/php/pgrouting.php?startpoint=89314.61677724583%20123959.32146482218&finalpoint=90696.99736799067%20123514.05047980057&method=SP"
I don't have to define password of database in php file?
Em 10-07-2012 13:22, Daniel Kastl escreveu:
On Tue, Jul 10, 2012 at 12:47 PM, Pedro Costa <pedrocostaarma@sapo.pt <mailto:pedrocostaarma@sapo.pt>> wrote:
I'm confused.
If yes, i just need to convert to my table srs (900913) correct?Hi Pedro,
OpenLayers uses World Mercator projection (900913 and there are some aliases), so start point and end point in the workshop need to be transformed to 4326.In your case you had to replace 4326 with 27492, I guess, assuming that you use OpenLayers (GeoExt) and your dataset.
Daniel
Thanks
Hi Pedro,
different.
<pedrocostaarma@sapo.pt <mailto:pedrocostaarma@sapo.pt>> wrote:I'm trying to adapt this function (findnearestedge) [1] to my
thanks
[1]
FROM ".TABLE."
Hi Pedro,
Daniel[1]
Pedro
Hi Pedro,
You need to check your webserver and PostgreSQL log file.
Can you run SQL queries directly in your Terminal window?
Do you have postgresql extension for PHP installed?
Daniel
Now i’m trying everything but i get this error in firebug:“NetworkError: 500 Internal Server Error - http://mydomain.pt/routing/php/pgrouting.php?startpoint=89314.61677724583%20123959.32146482218&finalpoint=90696.99736799067%20123514.05047980057&method=SP”
I don’t have to define password of database in php file?
I’m confused.
Daniel
Thanks
Hi Pedro,
thanks
[1]
FROM “.TABLE.”
Hi Pedro,
Hi guys,
Pedro
Em 10-07-2012 16:31, Daniel Kastl escreveu:
yes and yes. postgresql extension for PHP is something called 'pg' right?
In main log of postgresql i have a lot of things of another time so i clean it and test again.....
Em 10-07-2012 16:43, Pedro Costa escreveu:
It is pgsql.so?
On Ubuntu the package name is “php5-pgsql”
http://packages.ubuntu.com/precise/php5-pgsql
Daniel
It is pgsql.so?
it's installed..
In postgresql log i don't have nothing after i try the routing.
Can you see my code:
client: http://pastebin.com/vCuLDQru
server: http://pastebin.com/tdWDgj54
I'm using only one algorithm (renamed to SP) and i want to find only the nearest vertices...
Em 10-07-2012 17:01, Daniel Kastl escreveu:
On Ubuntu the package name is "php5-pgsql"
http://packages.ubuntu.com/precise/php5-pgsqlDaniel
On Tue, Jul 10, 2012 at 5:53 PM, Pedro Costa <pedrocostaarma@sapo.pt <mailto:pedrocostaarma@sapo.pt>> wrote:
It is pgsql.so?
You’re missing quotation in line 11 … that’s when the code highlighting becomes weird.
Otherwise, try to output the SQL queries to the server log and then run the query in the terminal.
Like this you can see if your query is OK or not.
Daniel
right i corrected the missing quotation.
I'm already run the query in pgadmin and works....
You can see images attached of firebug.
I'm only received error when i click for the end point. That client get the point values [1] but have no response [2]...
Em 10-07-2012 17:12, Daniel Kastl escreveu:
You're missing quotation in line 11 ... that's when the code highlighting becomes weird.
Like this you can see if your query is OK or not.Daniel
I change the query routing putting a start and a end point in php testing if returns geojson but don't work...
in pgadmin with the same start and end point works
Em 10-07-2012 17:20, Pedro Costa escreveu:
I'm only received error when i click for the end point. That client get the point values [1] but have no response [2]...Em 10-07-2012 17:12, Daniel Kastl escreveu:
Hi Daniel
In apache log i found this error:
[error] an unknown filter was not added: PHP
[error] [client my client] PHP Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in 'my domain'/routing/php/pgrouting.php on line 42, referer:
Line 42 is my db data:
// Connect to database
$con = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER "Password=".PG_PASS);
do you know what is the problem?
Thanks
Hi Pedro,
When comparing your line with the workshop source on GitHub [1], I see that you added “password” to the connection string.
I think you’re missing a “.” before “Password” and are you sure the syntax is correct and it needs to be a capital “P”?
Daniel
[1] https://github.com/pgRouting/workshop/blob/master/web/php/pgrouting.php
On Wed, Jul 11, 2012 at 10:47 AM, Pedro Costa <pedrocostaarma@sapo.pt> wrote:
Hi Daniel
[error] [client my client] PHP Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in ‘my domain’/routing/php/pgrouting.php on line 42, referer:Line 42 is my db data:
$con = pg_connect(“dbname=”.PG_DB." host=“.PG_HOST.” user=".PG_USER “Password=”.PG_PASS);do you know what is the problem?
Thanks
And you’re maybe missing a space as well.
$con = pg_connect(“dbname=”.PG_DB." host=“.PG_HOST.” user=“.PG_USER.” password=".PG_PASS);
… might be better. Just ensure that “password” is correct.
Daniel
On Wed, Jul 11, 2012 at 12:14 PM, Daniel Kastl <daniel@georepublic.de> wrote:
Hi Pedro,
I think you’re missing a “.” before “Password” and are you sure the syntax is correct and it needs to be a capital “P”?Daniel
Hi Daniel
Thanks
Thanks Daniel...
I'm trying without defining password for now.
And now i get this error:
JSON.parse: unexpected character
Em 11-07-2012 11:14, Daniel Kastl escreveu:
Hi Pedro,
When comparing your line with the workshop source on GitHub [1], I see that you added "password" to the connection string.
I think you're missing a "." before "Password" and are you sure the syntax is correct and it needs to be a capital "P"?Daniel
On Wed, Jul 11, 2012 at 10:47 AM, Pedro Costa <pedrocostaarma@sapo.pt <mailto:pedrocostaarma@sapo.pt>> wrote:
Hi Daniel
domain'/routing/php/pgrouting.php on line 42, referer:Line 42 is my db data:
user=".PG_USER "Password=".PG_PASS);do you know what is the problem?
Thanks
highlighting becomes weird.Otherwise, try to output the SQL queries to the server log and
