I have a small question.
Most of the algos do not take turn restrictions into account.
If wanted to use for example pgr_ksp (k-shortest path) for example, then that algo will not take turn restrictions into account.
The only way i could think about making the algo’s work, is to rewire the graph table, so that nodes with turn restrictions, will be removed and instead adding longer edges instead to cover all the travel options. (for each edge, that contains the node in question, append and rewire, its a bit complicated but you should get the idea from my very limited description)
My question is, is there such a tool which extends the graph table as produced by either osm2po or osm2pgrouting for turn restrictions?
Is there a different solution i am missing?
Thanks for your help!
On 10/22/2013 4:50 AM, Yaron Lev wrote:
Yes this is correct. Only the TRSP code handles turn restrictions.
It might be feasible to implement the KSP algorithm on top of TRSP.
https://github.com/pgRouting/pgrouting/issues/206
If you are interested in developing something and submitting a pull request or funding this it would be a great contribution. Or if you have funding, we can look at getting getting something developed.
The only way i could think about making the algo's work, is to rewire
description)
Yes, when I researched ways to solve turn restriction, I did find articles about how it is possible to reconstruct a graph around turn restrictions by removing and adding edges to make a "regular" graph that would generate the equivalent of the turn restricted routes. But it seemed very complicated.
Not that I know of. I think the OSM routing engine does support turn restrictions, but it is not part of pgRouting.
Sorry not that I know of. This is a good suggestion.
-Steve
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
thanks, that was helpful as always
i will try to share the code to “fix” the graph, should i have enough time to implement this.
thanks.
On Fri, Oct 25, 2013 at 5:26 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
description)
Yes, when I researched ways to solve turn restriction, I did find articles about how it is possible to reconstruct a graph around turn restrictions by removing and adding edges to make a “regular” graph that would generate the equivalent of the turn restricted routes. But it seemed very complicated.
-Steve
