Can anybody confirm that the in the table are as follows
CREATE TABLE pointsOfInterest( pid BIGSERIAL,
x FLOAT,
y FLOAT,
edge_id BIGINT,
side CHAR,
fraction FLOAT,
the_geom geometry,
newPoint geometry );
pid primary key the table
x/y coordinates of teh point of interest
edge_id the nearest edge id to this point of interest
has a value of l r b ?
fraction ?
the_geom the geometry of the point
newPoint the nearest point on the edge that is closest to this point
Any suggestions welcome
Dave.
Hi Dave
Sorry I didnt make documentation about the new table,
I am on a trip, so for the moment I can tell you based on this code
https://github.com/pgRouting/osm2pgrouting/blob/master/src/database/pois_config.cpp#L49
There is no X / Y columns
fraction is the fraction of the edge
because 0 and 1 are whole numbers vertex_id would be the corresponding vertex of the point of interest
there is a column new_geom which would have the new geometry if a point was found in the topology (aka was not too far)
When I have time I will try to elaborate the documentation of this table,
Vicky
x FLOAT,
y FLOAT,
edge_id BIGINT,
side CHAR,
fraction FLOAT,
the_geom geometry,
fraction ?
Dave.
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
Thanks I will try and figure it out tomorrow.
an
I am currently having fun with the flow stuff
I think one of the issues is that this methods can generate a result, but you need to know what the result means!
Dave.
On 21 October 2017 at 14:49, Vicky Vergara <vicky@georepublic.de> wrote:
Hi Dave
Vicky
x FLOAT,
y FLOAT,
edge_id BIGINT,
side CHAR,
fraction FLOAT,
the_geom geometry,
fraction ?
Dave.
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
