I calculated the pgr_DrivingDistance for two costs (10 min, 20min). Then I used pgr_pointsAsPolygon in order to get polygons out of my points. Usually it works well, but sometimes the polygon with the "lower" cost covers some areas which the polygon with "higher" cost does NOT cover. Here is an example:
I guess that different optimal alpha value are used in the cases.
If specifying same alpha value doesn't solve the problem, please
create a ticket on
Github(Issues · pgRouting/pgrouting · GitHub) and upload
coordinate records(*.sql or *.csv)
to somewhere.
Ko
2016-01-04 20:24 GMT+09:00 Jakob Miksch <jakob.miksch@posteo.eu>:
Dear List,
example:
