I was just looking at Many to one version, the example reads
SELECT * FROM pgr_maxFlowPushRelabel(
'SELECT id,
source,
target,
c1.capacity as capacity,
c2.capacity as reverse_capacity
FROM edge_table JOIN categories AS c1 USING(category_id), categories AS c2
WHERE edge_table.reverse_category_id = c2.category_id
ORDER BY id'
, ARRAY[6, 8, 12], 11
ie get the max flow from nodes 6 8 and 12 to 11
The listed result sets says
seq | edge_id | source | target | flow | residual_capacity
1 | 10 | 5 | 10 | 100 | 30
2 | 8 | 6 | 5 | 100 | 30
3 | 11 | 6 | 11 | 130 | 0
4 | 12 | 10 | 11 | 100 | 0
5 | 13 | 12 | 11 | 50 | 0
The results list includes reference from 6 and 12 BUT NOTHING from 8
if I remove the ORDER BY id clause I get
2 | 11 | 6 | 11 | 130 | 0
3 | 8 | 6 | 5 | 50 | 80
4 | 7 | 8 | 5 | 50 | 0
5 | 12 | 10 | 11 | 100 | 0
6 | 13 | 12 | 11 | 50 | 0
ie the result for node 8 is included, is the order by a requirment? is this a bug ?
regards
Dave.
