I am considering to use pgrouting for routing in layered data. By layered data i mean data that is separated in floors, which are in some points connected via elevators/stairs between the floors.
As far as I can see, this is not directly supported. Is it done any assumptions/choices which makes such an difficult/impossible to implement? How well will it work to just add connections between nodes in same floor (+elevators)?
best regards
Gunnar Rangøy
Gunnar Rangøy,
Systemutvikler / System developer,
Trådløse Trondheim / Wireless Trondheim,
(+47) 99360699
Hello Gunnar,
I can not think of any reason that we can not route this kind of data. The issue will be that you need to separate the nodes one different floors with a z-value and add an appropriate cost for elevators and stairs. elevators need to include some queue time for the elevator to arrive and then some travel time. For stairs you might want to set different costs for going up vs down.
The original pgRouting, pgDijkstra, was created for a Swiss university
campus to show the path from one classroom to another in different
buildings.
So, this is definitely possible.
Mario.
On Wed, Sep 28, 2011 at 12:36 AM, Stephen Woodbridge
<woodbri@swoodbridge.com> wrote:
On 9/27/2011 3:50 AM, Gunnar Rangøy wrote:
Hello,
Hello Gunnar,
vs down.
You can try it out here: http://plan.epfl.ch/
The “campus routing” also allows to set “disabled” flag for those, who can’t use stairs for example.
I think the application is a bit difficult to use if you don’t know room numbers. You can input the building ID for example, but this obviously won’t route you between floors.
In general pgRouting can handle different levels when you model your network right.
You need to add links between the different levels and assign costs.
Hello Gunnar,
vs down.
Hello Gunnar,
vs down.
