Does anyone know anything about postgresql 9.1 and postgis 2 withpgrouting?
There will be some sort of compatibility?
Thanks
Pedro
Thanks
Pedro
Yes I had them install and running PosgreSQL 9.1.3, postGIS 2.0 and pgrouting on win 7-32bits
El 22/05/2012 7:05 am, Pedro Costa escribió:
There will be some sort of compatibility?Thanks
Pedro
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS INFORMATICAS...
CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCIONhttp://www.uci.cu
http://www.facebook.com/universidad.uci
http://www.flickr.com/photos/universidad_uci
http://www.uci.cu
Em 22-05-2012 16:48, Jorge Fuentes escreveu:
Hi Jorge,
It was necessary to any change in code? Or were the normal procedures?
Thanks
Was just easy like double clik and next next...
but a had to download binaries from (I don't remember)
.. but I'm sure that you will find that url in older post or googlering it..
and be sure that you had postgreSQL 9.1.3 32 bit because i try with 9.1.1 and not work because a dll change from that version to 9.1.3
remember to execute .slq file from pgrouting
best regards
Hi Jorge,
Thanks
http://www.uci.cu
Hi Pedro,
If you use pgRouting on Windows, download module from here(https://github.com/sanak/pgrouting/downloads - pgRouting-git-sanak-mingw_20120310_pg-9.1(x86).zip).
Because above module was based on git master branch(https://github.com/pgRouting/pgrouting) after justjkk’s latest commit(2011/08/08), some drnextgis’s sql fixes had already applied after release 1.0.5,
but more drnextgis’s fix(https://github.com/pgRouting/pgrouting/pull/50) may be necessary.
Hi Jorge,
Thanks for your report about PostgreSQL version incompatibility.
I will check about this problem.
Sorry for my english.
2012/5/23 Jorge Fuentes <jfuentes@estudiantes.uci.cu>
Was just easy like double clik and next next…
but a had to download binaries from (I don’t remember)
… but I’m sure that you will find that url in older post or googlering it…
Hi Jorge,
Thanks
http://lists.osgeo.org/mailman/listinfo/pgrouting-users10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS INFORMATICAS…
http://www.flickr.com/photos/universidad_uci10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS INFORMATICAS…
Perfect…works…
Thanks
Hi Pedro,
Would be very grateful if you'd provide a short summary of what you
did to get it all working - along with links to the download packages?
Thanks
James
On 23 May 2012 11:13, Pedro Costa <pedrocostaarma@sapo.pt> wrote:
Perfect....works....
Thanks
Em 22-05-2012 23:42, Sanak escreveu:
Hi Pedro,
branch(https://github.com/pgRouting/pgrouting) after justjkk's latest
commit(2011/08/08), some drnextgis's sql fixes had already applied after
release 1.0.5,
but more drnextgis's fix(https://github.com/pgRouting/pgrouting/pull/50) may
be necessary.Hi Jorge,
I will check about this problem.Sorry for my english.
it..
pgrouting on win 7-32bitsHi Jorge,
Thanks
INFORMATICAS...
INFORMATICAS...
http://lists.osgeo.org/mailman/listinfo/pgrouting-users_______________________________________________
Hello James,
Of course. I have win7 64 bits with postgresql 9.1.2 and postgis 1.5.3. I'm only copy the binaries [1] to the C path.
Now I will try with postgis 2.0 and return the results.
Thanks
[1] https://github.com/sanak/pgrouting/downloads
Em 23-05-2012 11:18, James David Smith escreveu:
Hi Pedro,
did to get it all working - along with links to the download packages?Thanks
James
Thanks
Hi Pedro,
release 1.0.5,
2012/5/23 Jorge Fuentes<jfuentes@estudiantes.uci.cu>
it..
Thanks
INFORMATICAS...
INFORMATICAS...
Is there a build for postgis under windows in a 64bit enviroment ?
thanks
2012/5/23 Pedro Costa <pedrocostaarma@sapo.pt>
Hello James,
Of course. I have win7 64 bits with postgresql 9.1.2 and postgis 1.5.3. I’m only copy the binaries [1] to the C path.
Now I will try with postgis 2.0 and return the results.Thanks
Hi Pedro,
Would be very grateful if you’d provide a short summary of what you
James
Perfect…works…
Thanks
Hi Pedro,
release 1.0.5,
it…
Thanks
INFORMATICAS…
INFORMATICAS…
Hi Ricardo,
I don’t know all of the windows binaries, but I have not build 64bit one yet.
PostGIS team have already supported windows mingw-64bit build,
http://postgis.refractions.net/pipermail/postgis-users/2012-April/033745.html
http://www.postgis.org/download/windows/#postgis-installers
and began to make more crossplatform build system.(I guess this means move to cmake/msvc in windows).
http://blog.opengeo.org/2012/05/17/postgis-code-sprint-recap/
So, if the demand for windows 64bit binary seems to be large,
I will begin to investigate about it on my git(https://github.com/sanak/pgrouting)
mingw/msvc branch.
2012/6/4 Ricardo Bayley <ricardo.bayley@gmail.com>
thanks
Hello James,
Hi Pedro,
James
Perfect…works…
Thanks
Hi Pedro,
release 1.0.5,
it…
Thanks
INFORMATICAS…
INFORMATICAS…
I’m trying now with postgis 2.0 and successfully create the template for routing based on postgis template 2.0.
The problem I found is the function assign_vertex that gives the following error:
NOTICE: CREATE TABLE will create implicit sequence “vertices_tmp_id_seq” for serial column “vertices_tmp.id”
CONTEXT: SQL statement “CREATE TABLE vertices_tmp (id serial)”
PL/pgSQL function “assign_vertex_id” line 15 at EXECUTE statement
ERROR: find_srid() - couldnt find the corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS table? Is there an uppercase/lowercase missmatch?
In postgis 2.0 we do not have table geometry_columns, anybody know how to solve this problem?
Thanks
Pedro
On 6/6/2012 12:53 PM, Pedro Costa wrote:
I'm trying now with postgis 2.0 and successfully create the templatefor
routing based on postgis template 2.0.The problem I found is the function assign_vertex that gives the
following error:NOTICE: CREATE TABLE will create implicit sequence "vertices_tmp_id_seq"
for serial column "vertices_tmp.id"
CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statementERROR: find_srid() - couldnt find the corresponding SRID - is the
uppercase/lowercase missmatch?In postgis 2.0 we do not have table geometry_columns, anybody know how
select Populate_Geometry_Columns();
should fix this.
-Steve
Thanks
Pedro
Em 05-06-2012 03:40, Sanak escreveu:
Hi Ricardo,
I don't know all of the windows binaries, but I have not build 64bit
one yet.
mingw/msvc branch.
<mailto:ricardo.bayley@gmail.com>>Is there a build for postgis under windows in a 64bit enviroment ?
thanks
<mailto:pedrocostaarma@sapo.pt>>Hello James,
Hi Pedro,
what you
James
<mailto:pedrocostaarma@sapo.pt>> wrote:Perfect....works....
Thanks
Hi Pedro,
justjkk's latest
release 1.0.5,
incompatibility.
<mailto:jfuentes@estudiantes.uci.cu>>Was just easy like double clik and next next...
it..
version to 9.1.3
were the normal procedures?Thanks
<mailto:Pgrouting-users@lists.osgeo.org>
INFORMATICAS...
DE LAS CIENCIAS
INFORMATICAS...
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.osgeo.org>
Hi Pedro,
If you were able to fix assign_vertex_id function for PostGIS 2.0, adding a ticket to the GitHub issue tracker [1] would be nice … and even better with some patch.
Daniel
[1] https://github.com/pgrouting/pgrouting/issues?state=open
On Wed, Jun 6, 2012 at 8:00 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
I’m trying now with postgis 2.0 and successfully create the templatefor
following error:NOTICE: CREATE TABLE will create implicit sequence “vertices_tmp_id_seq”
PL/pgSQL function “assign_vertex_id” line 15 at EXECUTE statementERROR: find_srid() - couldnt find the corresponding SRID - is the
to solve this problem?select Populate_Geometry_Columns();
should fix this.
-Steve
Thanks
Pedro
Hi Ricardo,
one yet.
mingw/msvc branch.
2012/6/4 Ricardo Bayley <ricardo.bayley@gmail.commailto:[ricardo.bayley@gmail.com](mailto:ricardo.bayley@gmail.com)>
thanks
mailto:[pedrocostaarma@sapo.pt](mailto:pedrocostaarma@sapo.pt)>
Hello James,
Hi Pedro,
what you
James
mailto:[pedrocostaarma@sapo.pt](mailto:pedrocostaarma@sapo.pt)> wrote:
Perfect…works…
Thanks
Hi Pedro,
justjkk’s latest
release 1.0.5,
incompatibility.
mailto:[jfuentes@estudiantes.uci.cu](mailto:jfuentes@estudiantes.uci.cu)>
it…
version to 9.1.3
Pgrouting-users@lists.osgeo.orgmailto:[Pgrouting-users@lists.osgeo.org](mailto:Pgrouting-users@lists.osgeo.org)
INFORMATICAS…
DE LAS CIENCIAS
INFORMATICAS…
Pgrouting-users@lists.osgeo.org mailto:[Pgrouting-users@lists.osgeo.org](mailto:Pgrouting-users@lists.osgeo.org)
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Em 06-06-2012 19:00, Stephen Woodbridge escreveu:
should fix this.
-Steve
Hi Steve,
I did it but the error continues.
The result of select populate_geometry_columns was that:
"probed:1 inserted:0"
Hi Daniel,
I don’t know how to fix that but if anybody have an idea i can spent some time trying…
any tips on how to solve the problem?
I created a new ticket:
https://github.com/pgRouting/pgrouting/issues/58
thanks
