I’m running on Ubuntu and getting pgRouting from the ppa.
Is Postgresql v.9.1 the only version supported?
I believe that my clients are using 9.2.
Worth Lutz
Worth Lutz
It’ll work fine with 9.2.
Worth Lutz
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
I assume you mean if it is built from source.
I usually load from the ppa:georepublic/pgrouting
I try to avoid building stuff myself unless absolutely necessary.
So I guess my question is: must I build from source or will other versions be available from the ppa?
Worth
From: pgrouting-users-bounces@lists.osgeo.org [mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of James David Smith
Sent: Friday, September 27, 2013 2:37 PM
To: pgRouting users mailing list
Subject: Re: [pgrouting-users] postgres version for pgrouting?
Worth Lutz
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4142 / Virus Database: 3604/6700 - Release Date: 09/26/13
I believe Daniel plans to create other versions. I know he has been busy so I can't say when it will happen, but now that 2.0 is released I'm sure it will happen as soon as he has time to create them.
-Steve
versions be available from the ppa?Worth
[mailto:pgrouting-users-bounces@lists.osgeo.org] *On Behalf Of *James
David Smith
*Sent:* Friday, September 27, 2013 2:37 PM
*To:* pgRouting users mailing list
*Subject:* Re: [pgrouting-users] postgres version for pgrouting?It'll work fine with 9.2.
On 27 Sep 2013 19:31, "Worth Lutz" <wal3@mindspring.com
<mailto:wal3@mindspring.com>> wrote:I’m running on Ubuntu and getting pgRouting from the ppa.
Worth Lutz
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-users------------------------------------------------------------------------
Checked by AVG - www.avg.com <http://www.avg.com>
Version: 2014.0.4142 / Virus Database: 3604/6700 - Release Date: 09/26/13_______________________________________________
Thanks Steve,
I thought that may be the case but wanted to be sure.
I mucked up something on my dev machine trying to add 9.1 and was having
great problems with "create extension pgrouting". I do not know what
happened but I seem to have fixed it somehow.
Is "stable" the best place to get pgRouting. It seems like "unstable" had
"rc1".
What is the policy on what is in "stable" and what is in "unstable"?
Worth
-----Original Message-----
[mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Friday, September 27, 2013 3:32 PM
To: pgrouting-users@lists.osgeo.org
-Steve
David Smith
<mailto:wal3@mindspring.com>> wrote:I'm running on Ubuntu and getting pgRouting from the ppa.
Worth Lutz
On 9/27/2013 4:15 PM, Worth Lutz wrote:
Thanks Steve,
happened but I seem to have fixed it somehow.Is "stable" the best place to get pgRouting. It seems like "unstable" had
"rc1".
I think Daniel will need to answer this. Once he rebuilds everything I suspect that everyone will get initially sync'd to 2.0
After that, unstable will probably track the develop branch, which at the moment is the same as master except for some documenation edits.
I think stable tracks master and unstable tracks develop branches.
-Steve
Worth-----Original Message-----
Woodbridge
Subject: Re: [pgrouting-users] postgres version for pgrouting?I believe Daniel plans to create other versions. I know he has been busy
sure it will happen as soon as he has time to create them.-Steve
David Smith
Worth Lutz
http://lists.osgeo.org/mailman/listinfo/pgrouting-users_______________________________________________
Thanks, that makes sense to me.
Woodbridge
Sent: Friday, September 27, 2013 4:21 PM
Thanks Steve,
"rc1".
-Steve
Woodbridge
David Smith
Worth Lutz
HI Worth,
The pgRouting versions in the PPA are always for the PostgreSQL version that is default in Ubuntu.
And the default version is since 12.04 is PostgreSQL 9.1
It seems that the next version of Ubuntu will still have PostgreSQL 9.1, so it’s not going to change.
With Travis we test pgRouting also with other versions of PostgreSQL, so 9.2 should work.
https://github.com/pgRouting/pgrouting/blob/master/tools/travis/pgrouting_install.sh
But you have to compile yourself, because I’m not able to maintain this as PPA in my spare time.
Daniel
Worth
Subject: Re: [pgrouting-users] postgres version for pgrouting?It’ll work fine with 9.2.
Worth Lutz
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
