I am having a problem with a route taking the long way around when two edges have the same nodes.
I have used dijkstra_sp_delta and astar_sp_delta and get the same results.
This is my first attempt to do routing and it works easily. I took my street db and added the routing stuff and went at it.
What could be causing the routing algorithm to take the long way when choosing between the two edges?
Dijkstra and Astar algorithm route from node to node with a cost assigned.
They don’t check if there are more than one possibility and take just the first one.
You can either split “parallel” ways into two, or you can use Shooting Star, because it routes from road segment to road segment.
Thanks for the explanation. I'll keep plugging at it.
Worth
_____
[mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of Daniel Kastl
Sent: Thursday, October 13, 2011 12:00 PM
To: pgRouting users mailing list
Subject: Re: [pgrouting-users] problem with 2 edges with same endpoints
They don't check if there are more than one possibility and take just the
first one.
You can either split "parallel" ways into two, or you can use Shooting Star,
