I have a problem with shortest_path_shooting_star and shootingstar_sp
I use pgRouting-1.03_pg-8.3.7 with postgresql-8.3.10-1-windows and postgis-pg83-setup-1.3.3-1
For Data, i use a personal data.
I create my graph and I add “temps” as “cost” and “reverse_temps” as “reverse_cost” and I set reverse_temps=1000000 when direction=1.
When I run shortest_path_shooting_star :
$sql = "SELECT roads.edge_id0, AsText(roads.the_geom) AS wkt, roads.length, roads.gid
FROM roads, (SELECT edge_id FROM shortest_path_shooting_star(‘SELECT gid as id, source, target,temps as cost,reverse_temps as reverse_cost, x1, y1, x2, y2, rule, to_cost FROM roads order by id’,
“.$startEdge[‘gid’].”,
“.$endEdge[‘gid’].”,
true, true)) as rt
WHERE “.TABLE.”.gid=rt.edge_id;";
Pgrouting return a bad calcul (it not considerate reverse_cost : figure 1)
Value 0 : both trajet
Value 1 : one direction (drawing direction)
When I use shootingstar_sp :
$sql = "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
length(rt.the_geom) AS length, “.TABLE.”.id
FROM “.TABLE.”,
(SELECT gid, the_geom
FROM shootingstar_sp(
‘“.TABLE.”’,
1, ‘temps’,true,true)
) as rt
WHERE “.TABLE.”.gid=rt.gid;";
I have a similar result (figure 1).
But when I use :
FROM “.TABLE.”,
‘“.TABLE.”’,
1, ‘temps’,true,false)
) as rt
I have a correct result (figure 2), but my graph will not be oriented and I whill have bad calcul when I navigate between roads who have both direction (figure 3 is correct but figure4 is not correct).
Thanks
