On 3/10/2012 2:20 AM, Aurélien FILEZ wrote:
This table is build with lines I decompose in segments of 2 points.
Maybe it is better to act from these full lines, searching points used
by more than one line ?
Yes, but the question that I am trying to answer is How are you going to do the efficiently?
I just noticed that you already have v1 and v2 assigned, so you can do something like this:
create table vertices_tmp as
select id, count(*) as cnt from
(select v1 as id from edge union all select v2 as id from edge) as foo group by id;
Now to find all the the nodes where cnt=2
select id from vertices_tmp where cnt=2;
And you write a stored procedure to merge the two edges.
-Steve
Kin
On Fri, Mar 9, 2012 at 5:48 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
On 3/9/2012 11:39 AM, Aurélien FILEZ wrote:
My edge table has some useless nodes. For example :
edge_id v1 v2 the_geom
1 1 2 LINESTRING(x1 y1, x2 y2)
2 2 3 LINESTRING(x2 y2, x3 y3)
But the vertex 2 is no used in any other edge.
So I would like reduce my graph to transforme this previous
example to :
1 1 3 LINESTRING(x1 y1, x2 y2, x3 y3)
Is there is a way to do that ?
Thank you all ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
There is no automatic way to do this. I have done a lot of graph
analysis by adding a cnt column to the vertices_tmp column and then
updating it to the count of edges connected to that vertex.
Then you can do things like look for:
deadends - cnt=1
connected lines - cnt=2
You could write a stored procedure to that the connected lines, join
them together, and update the relevant tables to reflect the new
topology.
-Steve
______________________________ _________________
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo. org
<mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/ mailman/listinfo/pgrouting- users
<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
