Great! Glad I could help and that you were able to get things going.
Steve,
I followed your instructions and it worked like a magic. Thanks for
helping me with this task.
Raghavan
On Thu, Jan 16, 2014 at 4:56 PM, Raghavan Krishnasamylakshmanaperumal
<rkrish20@uic.edu <mailto:rkrish20@uic.edu>> wrote:
Steve,
Sure I will try following the above mentioned steps. Hope this will
guide me to further proceed in my work.
Thanks for sharing your knowledge.
Raghavan
On Thu, Jan 16, 2014 at 4:11 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
On 1/16/2014 4:54 PM, Raghavan Krishnasamylakshmanaperumal wrote:
Steve,
Thanks for pointing out various resources, probably I didn't
explain
about my data properly. So the data which I have is not just
two points,
I have collected data from my and some of my friend's runkeeper
<http://runkeeper.com/> GPS traces for various activities
like running,
walking, biking in and around Chicago. I have all these GPS
points(longitude,latitude) information with me. What I am
trying to find
is the shortest path given any two points from the data
which I have
collected.
Then you should be able to:
1. load the track points into a table
2. convert the tracks into linestrings
3. then run pgr_nodenetwork
4. update the resulting table to include costs or lengths
5. then run pgr_createTopology
6. then map a start point and end point to the network nodes
7. call pgr_dijkstra to get shortest path
All of the above happens in the database
8. write a client application the connects to the database maps
the start and end points, computes the path and displays it or
whatever you need to do with it.
-Steve
Raghavan
On Thu, Jan 16, 2014 at 3:42 PM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.__com
<mailto:woodbri@swoodbridge.com>>> wrote:
On 1/16/2014 4:31 PM, Raghavan
Steve,
Thanks for your reply, I think I almost understood.
So you say that
having only these GPS point may not help me I
should also have the
network map corresponding to these GPS points using
which I can
figure
out the shortest path?
if you only have two point on the earth and nothing
more what is the
shortest path. "Path" implies that you have a network
of paths and
that you want to find the the shortest path within the
network. If
you only have the points and no network then you can
not find the
shorth path in the network, because you do not have one.
The way things works is that we take a point and find
the nearest
edge ot node in our network for that point and that
then becomes the
start or end point in the network. Dijkstra then
searchs the network
for the shortest path between two points.
So right now I have only these GPS points, how
should I proceed
further
to figure out the shortest path between any two GPS
points from
my data.
You can't do anything with just these points. You have
to make them
to a network and then search for a solution within that
network.
So you have to find network data that you can use for
your area of
interest. You might look at OSM data and osm2pgrouting
to load it
into pgRouting.
You could also look into using Project-OSRM (requires
64bit HW)
which is the router used by OSM.
I am open to use any database/framework/language so
please
suggest me
how to proceed further and I am concerned about
scalability or
other
factors because this is just a proof of
concept(course project)
which I
am trying to build.
Project-OSRM
google: java dijkstra
There are lots of choices, but all require that you
have network data.
-Steve
Raghavan
On Thu, Jan 16, 2014 at 12:21 PM, Stephen Woodbridge
<mailto:woodbri@swoodbridge.>____com
<mailto:woodbri@swoodbridge.com>>>> wrote:
On 1/16/2014 12:46 PM, Raghavan
wrote:
Recently I started using PostGIS for my
academic
project which is a
route recommendation system. I have stored
the data in the
following format.
/gid=>integer, activity=>varchar(20), geom
geometry(Point,4326)/
geometry points are longitude and latitude
information, for
example if
you record your Running activity using a
gps device,
each point
record
(longitude & latitude) is stored in the
geom column.
The shortest distance between two points is a
straight line
unless
you want to constrain the problem to the
shortest distance
along
some road or path network.
If it is constrained to a networks of paths
then you have
to have
the data for that network available.
In the case of pgRouting, you have to load the
network data and
prepare it for routing, then you can use you
points as the
start and
end points of a route and ask pgRouting to
fins the
shortest path
between them along the network.
I need to find the shortest path(using
Dijkistra's)
between any
two geom
points from this data set and I am trying
to automate
this using
some
programming language like Java.
With Java you can connect to the database and
issue simple
queries
to pgRouting to get your results. If you are
looking for a Java
library to solve Dijkstra problems then this
is not
pgRouting. Also
if you are using a Java library you will still
need to load the
network of paths that you want to solve you
queries against.
Hope this helps,
-Steve
Please can you suggest me how to make use
of pgrouting and
postgis data
to figure out the shortest path. Is there
any library
available to
automate this using Java. I am totally
stuck on my
project and
finally
came to know about this mailing list.
Thanks and Regards,
Raghavan KL
_____________________________________________________
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.______org
<mailto:Pgrouting-users@lists.
<mailto:Pgrouting-users@lists.>____osgeo.org <http://osgeo.org>
<mailto:Pgrouting-users@lists.__osgeo.org
<mailto:Pgrouting-users@lists.osgeo.org>>>
http://lists.osgeo.org/______mailman/listinfo/pgrouting-______users
<http://lists.osgeo.org/____mailman/listinfo/pgrouting-____users>
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users>>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>>>
Thanks and Regards,
Raghavan KL
Pgrouting-users@lists.osgeo.____org
Thanks and Regards,
Raghavan KL
Pgrouting-users@lists.osgeo.__org
Thanks and Regards,
Raghavan KL
Thanks and Regards,
Raghavan KL
