Hello all:
pgROuting Team is pleased to announce 3 releases:
pgRouting version 2.5.1
osm2pgrouting version 2.3.0
pgRoutingLayer version 2.2.0
See details bellow
regards.
pgRouting Team
To see the issues closed by this release see the Git closed milestone for 2.5.1 on Github.
Bug fixes- Fixed prerequisite minimum version of: cmake
Can be downloaded from [1]
Documentation can be found on [2]
[1] [https://github.com/pgRouting/pgrouting/releases/tag/v2.5.1](https://github.com/pgRouting/pgrouting/releases/tag/v2.5.1)
[2] [http://docs.pgrouting.org/2.5/en/index.html](http://docs.pgrouting.org/2.5/en/index.html)
To view the full list of issues:
Main changes are:
- Cost should not return the same value
- Added a points of Interest table
- Some default one_way values are taken into consideration
- Relations are also considered
- New mapconfig_for_pedestrian.xml
New Flags
--attributes Include attributes information.
--tags Include tag information.
--chunk arg (=20000) Exporting chunk size.
--no-index Do not create indexes (Use when indexes are already created)
Can be downloaded from [3]
Documentation can be found on [4]
Sorry I haven't got time to update it but its basically the same as on:
[https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.2](https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.2)
[3] [https://github.com/pgRouting/osm2pgrouting/releases/tag/v2.3.0](https://github.com/pgRouting/osm2pgrouting/releases/tag/v2.3.0)
[4] [https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.3](https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.3)
On QGIS plugins, select pgRoutingLayer and click on "upgrade Plugin"
Documentation can be found on [5]
Whith this release of pgRoutingLayer
- BBOX is optional
- Supports pgRouting v2.0 up to v2.5
- Menu shows non deprecated functions of the corresponding version only.
[5] [https://github.com/pgRouting/pgRoutingLayer/wiki/Documentation-v2.2](https://github.com/pgRouting/pgRoutingLayer/wiki/Documentation-v2.2)
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
