Hi to all,
I’m trying to make routing with pg_routing algorithms.
But i’m ahving problems with one way roads. Algorithm insists on using opposite directional roads even i’m using the biggest reverse_cost value.
Here is the algorithm that i’m using.
SELECT * FROM shortest_path_shooting_star(
‘SELECT gid as id, class_id, source, target, lengthc.cost as cost,
x1, y1, x2, y2, rule, to_cost, reverse_costc.cost as reverse_cost
FROM ways w, classes c
WHERE class_id=c.id’, 1450296, 1468993, true, true);
the algorithm always ignores the reverse_cost and insists on using opposite directional roads.
Could you help me to solve this problem?
You can find a snap_shot about this problem in the attachment.
Thanks for your help
![routing_error.JPG](/uploads/default/original/1X/ea48249382a662eed1a84b0d99f99e541c4b57da.jpeg)
I asked about this a few days ago and Steve mentioned that the shooting star algorithm for one-ways may be broken on 1.05. I switched to Dijkstra and everything works fine for me now…
On Thu, Dec 8, 2011 at 9:29 AM, Mehmet Hilmi Elihos <elihos@gmail.com> wrote:
Hi to all,
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Hi I sent an email a couple of weeks ago, maybe I didnt write in a good way because no one answered it.
I got same problems with Dijkstra too, it chose opposite ways even though with a huge cost.
I can send the example if someone is interested, anyways Im afraid I can not use pgrouting at least in 1.05 version with one way roads.
regards,
Jose
