Thanks a lot Steve, this looks really helpful. I can see that routing involves much of the same "art" that geocoding does.
Based on past experience, I'm not sure that the road network I am working with is as clean as you and Daniel appear to assume. I'm going to look at the dead-end and other issues tomorrow. I'm also wondering if there is any potential benefit of reading the original shapefile into GRASS which will attempt to clean it, dumping it back into a shapefile from GRASS, and then importing it into PostGIS, or does assign_vertex_id basically do the same cleaning that GRASS does?
Dan
--- On Thu, 8/26/10, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Subject: Re: [pgrouting-users] Setting the tolerance argument in assign_vertex_id
To: "Dan Putler" <putler@yahoo.com>
Cc: "pgRouting list" <pgrouting-users@lists.osgeo.org>
Received: Thursday, August 26, 2010, 8:55 PM
Dan,
I think that picking a number around 0.5 to 1 meter should
be fine for
that data. In general it is unlikely that you will have
nodes that are
NOT connected but that close together.
You can also do some analysis of the results like this,
after you run
assign_vertex_id():
alter table vertices_tmp add column cnt int;
update vertices_tmp set cnt = (select count(*) from
"<edge_table>"
where vertices_tmp.id=target or
vertices_tmp.id=source);
select cnt as connections, count(*) from vertices_tmp
group by cnt order by cnt;
This will analyze the connectedness of you network.
connections
1 - dead ends
2 - segments connected
but only an intersection if different names
3+ - intersections
If you run assign_vertex_id() with different tolerance
values and then
run this analysis as your tolerance gets too big you will
see a shift of
these numbers to the smaller end which is bad.
Another important analysis you check is:
select count(*) from "<edge_table>" where
target=source;
this count should be zero unless you have zero length
segments in your
data and you can check that with:
select gid, st_length(the_geom) from "<edge_table>"
where target=source;
These are a good way to learn about your data.
-Steve
On 8/26/2010 8:37 PM, Dan Putler wrote:
> Thanks Steve, but I do need a bit of a follow on I
think, and
> probably provide a bit more explanation.
> I'm using a DMTI CanMap routing layer for BC that
started out in
> NAD83 geographic, which I converted to NAD83 UTM Zone
10N via
> ogr2ogr, I also shrank it down using a "with"
statement in ogr2ogr to
> cover only part of the province. After I sent my
email, I did a bit
> more Google searching and based on a question in the
pgRouting forum,
> a user using NAVTEQ layers was using a tolerance that
worked out to
> between 1 and 1.5 meters. Based on this, I set the
tolerance to 2
> meters, it sounds like I should set the tolerance in
assign_vertex_id
> to be much smaller (say 0.15 meters, which is just
over 5 inches).
> In general, is it better to err on the side of too
small or too large
> a tolerance, or is that a "it depends" question?
> Dan
> --- On Thu, 8/26/10, Stephen Woodbridge<woodbri@swoodbridge.com>
> wrote:
>> From: Stephen Woodbridge<woodbri@swoodbridge.com>
Subject: Re:
in
>> assign_vertex_id To: "Dan Putler"<putler@yahoo.com>
Cc: "pgRouting
>> list"<pgrouting-users@lists.osgeo.org>
>> 26, 2010, 4:27 PM On 8/26/2010 2:51 PM, Dan Putler
wrote:
>>> Hi,
>>> I'm curious how to determine the value of the
second
>> argument in the
>>> function assign_vertex_id(). Most of the
examples I
>> can find look
>>> like:
>>> assign_vertex_id('<edge table>', 0.001,
>> 'the_geom', 'gid')
>>> Most of the examples are based on edge tables
that
>> have SRIDs that
>>> correspond to either WGS84 geographic or some
sort of
>> US State Plane
>>> feet. I'm using data that is using a UTM
coordinate
>> SRID, so the map
>>> units are in meters. My question is whether
the map
>> units should
>>> influence the choice of the second argument to
the
>> function (which I
>>> assume is a tolerance between edges), or
should I just
>> keep with the
>>> value 0.001? Implicitly, I'm asking if the
parameter
>> is in the map
>>> units of the SRID.
>> Dan,
>> Right units is important.
>> When I use data in WGS84 that has at lease 6
decimal places then I
>> use 0.000001 as the tolerance. What this means if
that if the
>> distance between two points are less than or equal
0.000001 units
>> then they should be considered the same point.
0.000001 degrees ==
>> ~5 inches if I did the math right.
>> I think there are two issues you need to be aware
of:
>> 1) units 2) your data and what precision it was
built at
>> HTH, -Steve
