Dan,
In general the data is not represented as 2.5D, it is all 2D and there are relationship tables the tell you about zlevels.
Navteq uses zlevels and DMTI used to call it ren (Relative Elevation Nodes).
Also I noticed the DMTI rte (Roads) layer appears to have FromNode and ToNode already assigned to the road network. These are logical equivalents to source and target columns.
Well I have this info in my CanMap RouteLogistic v. 6.3 reference manual.
-Steve
On 8/27/2010 2:45 PM, Dan Putler wrote:
Hi Steve,
I'm getting the hang of the layer diagnostics. The data was
originally in a shapefile, and there is no z value in the attribute
table, so it doesn't appear to be a 2.5d file. It does have both
length and length adjusted for elevation fields, just no z. Your tips
on the diagnostics have been very helpful (translating what you did
with Mapserver into QGIS is pretty straight forward). Over 5% of the
edges have zero length, but these overwhelmingly occur on the loops
of cul-de-sacs. In addition, I'm not finding any mid-street dead
ends.Overall, I'm successful in routing between 85% and 90% of my test
cases using the shooting * algorithm. Some of the failures I'm
finding are very surprising, I have a hunch as to why some of them
are occurring (based on a likely two bridge, literal "island
hopping", route it would likely select), but so far I'm not finding a
problem in the road network with respect to dead-ends or zero length
segments that would cause it. The island hoping route does involve
two fairly complex interchanges, could the lack of detailed elevation
information on the interchanges be the cause of the problem?I'm going to look at a couple of things, one of them is to go back to
the original DMTI layer to make sure I didn't somehow screw-up the
data being too clever with ogr2ogr, the other is to see if I get a
solution using the Dijkstra algorithm.Again, thanks a lot for all your help.
Dan
--- On Fri, 8/27/10, Stephen Woodbridge<woodbri@swoodbridge.com>
wrote:From: Stephen Woodbridge<woodbri@swoodbridge.com> Subject: Re:
[pgrouting-users] Setting the tolerance argument in
assign_vertex_id To: "Dan Putler"<putler@yahoo.com> Cc: "pgRouting
list"<pgrouting-users@lists.osgeo.org> Received: Friday, August 27,
2010, 9:00 AM Dan,One more thing that you might want to consider is if the DMTI data
has zlevels at intersections, the you might need to mimic
assign_vertex_id() in the form of assign_vertex_id_3d() where you
update your edge endpoints with a Z value in the vertices_tmp table
and you set the Z value to zlevel*FACTOR where FACTOR greater than
TOLERANCESo if you have intersection points like at an overpass where the
under pass is A-B(0)-C and the overpass is J-B(1)-KB has and location (x,y) and the zlevel for A-B and B-C is 0 and
the for edges J-B and B-K the zlevel is 1, so while these are at
the same x,y they do not intersect. In the assign_vertex_id(),
these will get assigned the same node, but you need to write
assign_vertex_id_3d() so they would get different nodes assign
based on the zlevel separation.-Steve
On 8/27/2010 11:31 AM, Stephen Woodbridge wrote:
I think DMTI data is pretty high quality data. I have
used it in the
past, granted not for routing but, I never noticed any
quality problems.
When I did some of the analysis on other data sets, I
created extra
columns on the edges table an did things like mark the
edges for all
that had the same source and target nodes and display
them in using
mapserver and openlayers and displayed the
vertices_tmp table with
deadends as red dots and other nodes as green dots.
Then you can get a quick visualization of the data.
Mostly what you want
to look for is to see if deadends fall on connected
lines, this
indicates a problem. Look for segments with matching
source and target
numbers (color them so they stick out on the map.
If you set the tolerance wrong you will see lots of
errors like these.
I also then run pgRouting and overlay that on the maps
and can turn on
the reference layers for debugging weird routes.
Open the layer switcher, zoom in and select "Just the
Streets" and "Dead
Ends" and you can see what I mean. "Just the Streets"
labels the streets
with the gid of the edge table so you can go
investigate a problem.
-Steve
On 8/27/2010 3:44 AM, Dan Putler wrote:
Thanks a lot Steve, this looks really helpful. I
can see that routing
involves much of the same "art" that geocoding
does.
Based on past experience, I'm not sure that the
road network I am
working with is as clean as you and Daniel appear
to assume. I'm
going to look at the dead-end and other issues
tomorrow. I'm also
wondering if there is any potential benefit of
reading the original
shapefile into GRASS which will attempt to clean
it, dumping it back
into a shapefile from GRASS, and then importing it
into PostGIS, or
does assign_vertex_id basically do the same
cleaning that GRASS
does?
Dan
--- On Thu, 8/26/10, Stephen
Woodbridge<woodbri@swoodbridge.com> wrote:From: Stephen Woodbridge<woodbri@swoodbridge.com>
Subject: Re:
argument in
Cc: "pgRouting
Received: Thursday, August
26, 2010, 8:55 PM Dan,
I think that picking a number around 0.5 to 1
meter should be fine
for that data. In general it is unlikely that
you will have nodes
that are NOT connected but that close
together.
You can also do some analysis of the results
like this, after you
run assign_vertex_id():
alter table vertices_tmp add column cnt int;
update vertices_tmp
set cnt = (select count(*) from
"<edge_table>" where
vertices_tmp.id=target or
vertices_tmp.id=source); select cnt as
connections, count(*) from vertices_tmp group
by cnt order by cnt;
This will analyze the connectedness of you
network.
connections 1 - dead ends 2 - segments
connected but only an
intersection if different names 3+ -
intersections
If you run assign_vertex_id() with different
tolerance values and
then run this analysis as your tolerance gets
too big you will see
a shift of these numbers to the smaller end
which is bad.
Another important analysis you check is:
select count(*) from "<edge_table>"
where target=source;
this count should be zero unless you have zero
length segments in
your data and you can check that with:
select gid, st_length(the_geom) from
target=source;
These are a good way to learn about your
data.
-Steve
On 8/26/2010 8:37 PM, Dan Putler wrote:
Thanks Steve, but I do need a bit of a
follow on I
think, and
probably provide a bit more explanation.
I'm using a DMTI CanMap routing layer for
BC that
started out in
NAD83 geographic, which I converted to
NAD83 UTM Zone
10N via
ogr2ogr, I also shrank it down using a
"with"
statement in ogr2ogr to
cover only part of the province. After I
sent my
email, I did a bit
more Google searching and based on a
question in the
pgRouting forum,
a user using NAVTEQ layers was using a
tolerance that
worked out to
between 1 and 1.5 meters. Based on this, I
set the
tolerance to 2
meters, it sounds like I should set the
tolerance in
assign_vertex_id
to be much smaller (say 0.15 meters, which
is just
over 5 inches).
In general, is it better to err on the
side of too
small or too large
a tolerance, or is that a "it depends"
question?
Dan
wrote:
Subject: Re:
tolerance argument
in
Cc: "pgRouting
26, 2010, 4:27 PM On 8/26/2010 2:51
PM, Dan Putler
wrote:
I'm curious how to determine the
value of the
second
argument in the
function assign_vertex_id(). Most
of the
examples I
can find look
like:
assign_vertex_id('<edge
table>', 0.001,
'the_geom', 'gid')
Most of the examples are based on
edge tables
that
have SRIDs that
correspond to either WGS84
geographic or some
sort of
US State Plane
feet. I'm using data that is using
a UTM
coordinate
SRID, so the map
units are in meters. My question
is whether
the map
units should
influence the choice of the second
argument to
the
function (which I
assume is a tolerance between
edges), or
should I just
keep with the
value 0.001? Implicitly, I'm
asking if the
parameter
is in the map
units of the SRID.
Dan,
Right units is important.
When I use data in WGS84 that has at
lease 6
decimal places then I
use 0.000001 as the tolerance. What
this means if
that if the
distance between two points are less
than or equal
0.000001 units
then they should be considered the
same point.
0.000001 degrees ==
~5 inches if I did the math right.
I think there are two issues you need
to be aware
of:
1) units 2) your data and what
precision it was
built at
HTH, -Steve
_______________________________________________ Pgrouting-users
mailing list Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
