Hello there. I’ve got the query for shortest path using pgrouting to run finally. I get the edges but now I need to map my result onto a mapserver layer. I’ve tried examples from the internet but mostly they’re flawed. I’m positng the query which has worked for me. Please suggest a way to convert it into a visible layer using mapserver.
SELECT * FROM shortest_path(‘SELECT gid AS id, fromnodeid::int4, tonodeid::int4, length0::float8 AS cost FROM edges_line’, 35, 210, false, false)
I tried to form a query-layer but failed. I’m sending the code I used to. Please correct me.
DATA “the_geom FROM (SELECT * FROM shortest_path(‘SELECT gid AS id, fromnodeid::int4, tonodeid::int4, length0::float8 AS cost FROM edges_line’, 35, 210, false, false)) AS foo using unique gid using srid=4326”
Here is the layer definition:
LAYER
NAME “route”
CONNECTIONTYPE postgis
CONNECTION “user=postgres password=*********** dbname=VSDelhidb host=localhost”
DEBUG 5
STATUS DEFAULT
TYPE LINE
TEMPLATE “t”
//////////////////////////////////////////////////////THE CLASS THAT CLASSIFIES EVERYTHING IN IT. ////////////////////////////////
CLASS
/////////////////////////////////////////////////////THE STYLE OF DRAWING THIS CLASS. ////////////////////////////////////
NAME “0”
STYLE
SYMBOL “circle”
SIZE 10
OUTLINECOLOR 255 0 0
COLOR 165 42 42
END #END OF THE SYLE DECLARATION FOR THIS CLASS.#####################################################################
END #END OF THE CLASS THAT CLASSIFIES EVERYTHING._##############################################################
END #END OF THE LAYER THAT DRAWS EVERYTHING.##############################################################################
