Hi Tao,
On 9/9/2012 10:02 PM, Tao Romera Martinez wrote:
Dear Daniel and Stephen,
Thank you very much for your answers.
I have not had time to dive into the pgrouting source code and the
dijkstra algorithm, so I very much appreciate your detailed
explanation about the possibilities to speed up the algorithm.
I think that being able to dynamically generate the graph to be used
in the routing algorithm is a great function, but having the
possibility to work with a static graph would be fantastic if the
speed improvement is in the order of 10x-100x, especially for
web-related services, where the time response is crucial. I don't know
how much time it would take to implement this feature, but I
definitely put my vote for this one.
In the meanwhile, I would like to help in the implementation of the
via-TRSP (ie, the TRSP going through a set of points). Just one
question: what is the speed up order we can expect? If the dijkstra
algorithm itself is taking most of the time, I guess there is no point
in spending time implementing it, but if generating the graph is
consuming most of the processing time, the speed improvement could be
big.
It is hard to estimate this, the best thing to do would be to take some measurements. The time consists of the following:
1. time for SQL query and fetch the edges needed to build the graph
2. time for SQL query and fetch associated turn restrictions if any
3. time to build the graph
4. time to solve the graph
5. time to return the results
My assumption is that 1-3 take significant % of the total time. but there are a lot of variables, like how many edges are needed.
Stephen, I have not written a line of C for ages, but I can get to it
again if you allow some time for warming up. Also, I have an
intermediate level of SQL, and have been a heavy user of postgis and
pgrouting since April this year. Tell me how I can help you and I will
be more than eager to work on the via TRSP function!
So the way I would approach this is to:
1. figure out a new signature for calling this new method
2. make changes or write new code to implement the new signatures
The Current signatures for trsp are:
CREATE OR REPLACE FUNCTION turn_restrict_shortest_path(
sql text,
source_vid integer,
target_vid integer,
directed boolean,
has_reverse_cost boolean,
turn_restrict_sql text)
RETURNS SETOF path_result
AS '$libdir/librouting_trsp', 'turn_restrict_shortest_path_vertex'
LANGUAGE 'C' IMMUTABLE;
sql text,
source_eid integer,
source_pos float8,
target_eid integer,
target_pos float8,
directed boolean,
AS '$libdir/librouting_trsp', 'turn_restrict_shortest_path_edge'
So I think I might try changing this to be something like:
sql text, -- sql for the edges
point_eid integer, -- array of edge ids[start,via,...,end]
point_pos float8, -- array of position on edges [start,via,...,end]
directed boolean,
AS '$libdir/librouting_trsp', 'turn_restrict_shortest_path_vias'
This would call the C function turn_restrict_shortest_path_vias() and function similar in concept to turn_restrict_shortest_path_edge() but would compute multiple solutions on the assembled graph.
If you want to work on this, create a github account and fork pgrouting in your account and let me know where it is so I can clone it and see what you are doing. Then we can work together on it. I have not had time to look closely at the code, so things might change if we run into problems.
To get started you might want to clone pgrouting and add some code into trsp to raise notices with timing information to get a better idea of what each piece is costing.
-Steve
Tao
2012/9/9 Stephen Woodbridge <woodbri@swoodbridge.com>:
On 9/9/2012 5:59 AM, Daniel Kastl wrote:
On Sun, Sep 9, 2012 at 1:24 PM, Tao Romera Martinez <taoromera@gmail.com
<mailto:taoromera@gmail.com>> wrote:
Dear all,
I am using shortest_path() to find the shortest route between 2
points. I have a set of points (P1, P2, P3, P4...) through which I
want to go in order to reach the start and end points (S and E). Right
now, I am calling shortest_path() to link each pair of points
separately (S-P1, P1-P2, P2-P3, ...). The function shortest_path()
computes in 0.3 seconds, but since I have to call it many times, the
total time required to generate the final route gets quite high.
Does someone know how I could speed up the generation of the final
route (ie., the route going through all the points)? Is there a way of
calling shortest_path but with "via" points?
Unfortunately there is not such a function, as far as I know.
This is correct, no function like that today.
The optimization might be that you could build the graph once, then solve it
repeatedly for each consecutive pair of nodes. My guess is that this only
works well if the points are clustered in a small area as opposed to laid
out in a long linear path. The trade-off here is that creating N small
graphs and solving them each once versus creating one larger graph and
solving it N time.
I believe it would be pretty easy to build this in just the plpsql and C
wrappers. Something along these lines:
1. get the extents of the points and expand it
2. convert the points to edges or nodes
3. build the graph from the edges in the expanded extents
4. for each pair, solve the graph and return the edges
5. cleanup and return
If anyone has time or funding for this, I would be interested in doing this
for the TRSP algorithm. This has the best ability to match points in partial
edges and has support for turn restrictions.
Another way of solving this problem is to provide support for a faster
solver, like highway contraction hierarchy that is on our wish list. This
solves problems 10-100x faster but does not fit well into the pgRouting
structure of dynamically building graphs.
-Steve W
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
