Hello Dan,
Sure, you can send me the data as well.
Yasir
> *Hi Daniel,*
> *To follow on Yasir's comments in terms of routing results, I've been*
> *working with a simple example data set where the distance and travel time*
> *results are likely to be different (really there are several equally good*
> *routes based on distance, but a unique route based on travel time, but with*
> *the "length" field in the database reflecting travel time along an edge).*
> *When doing the routing based on travel time I get the correct solution using*
> _the Dijkstra algorithm, but an incorrect result using the A* and Shooting_
> *Star algorithms. The nature of the errors I'm getting would be consistent*
> *with what Yasir is finding. I'd be glad to send you both the network data*
> *and my test queries. I'm running on 64bit Ubuntu 10.04 using the Ubuntu*
> *repository version of PostgreSQL (8.4.4), PostGIS 1.5.1, and built pgRouting*
> *from the subversion repository on Tuesday.*
> *Dan*
> *--- On Fri, 7/16/10, Daniel Kastl <[daniel.kastl at georepublic.de](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)> wrote:*
> *From: Daniel Kastl <[daniel.kastl at georepublic.de](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)>*
> *Subject: Re: [pgrouting-users] Shortest Route Search Not Working*
> *To: [pgrouting-users at lists.osgeo.org](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)*
> *Received: Friday, July 16, 2010, 9:58 PM*
> *I hope you don't mind helping me with another couple short questions:*
> *1. Projection 4326 with latlng is lot easier for me to work with. Although*
> *there are ways to convert the latlng to*
> *900913 projection, I was wondering how would I be able to directly use*
> *4326 and run search on it (HTML changes), assuming that the tiles were*
> *generated with 900913 projection and the routing database is set to 4326?*
> *You can use Postgis "transform()" function to do this:*
> *[http://postgis.refractions.net/docs/ST_Transform.html](http://postgis.refractions.net/docs/ST_Transform.html)*
> *2. Just out of curiosity.*
> *The routing results usually take residential route ways, instead of taking*
> *instead of taking highway streets (which is more like what results from*
> *Google Maps show). Any ideas why the difference?*
> *pgRouting gives you the "shortest" path and it's up to you to define what*
> *is "shortest". Easiest is to take length as cost, but if you take time as*
> *cost, then shortest will be the fastest. You could for example define some*
> *speed for your road classes, and if the speed is higher on highways it will*
> *prefer the highway like Google Maps does.*
> *Daniel*
> *Thanks*
> *_______________________________________________*
> *Pgrouting-users mailing list*
> *[Pgrouting-users at lists.osgeo.org](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)*
> *[http://lists.osgeo.org/mailman/listinfo/pgrouting-users](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)*
> *-----Inline Attachment Follows-----*
URL: [http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20100718/4af3192b/attachment.html](http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20100718/4af3192b/attachment.html)
