Hi Sven,
This is an example query that solves the order problem :
SELECT rp.the_geom, rp.id_tron::integer, ST_AsGeoJSON(rp.the_geom) AS geojson, length(rp.the_geom) AS length, type_tron::integer, nom
FROM (SELECT edge_id, ROW_NUMBER() OVER (PARTITION BY 1) AS order_tron
FROM turn_restrict_shortest_path(
'SELECT id_tron::integer AS id, source::integer, target::integer,
cost::double precision, rev_cost::double precision AS reverse_cost
FROM reseau_global', 15326, 8756, true, true,
'SELECT to_cost::double precision, target_id::integer, via_path::text FROM reseau_global_rest')
) AS sp
JOIN (SELECT * FROM reseau_global) AS rp ON sp.edge_id = rp.id_tron ORDER BY order_tron;
This query is for trsp. That is why two queries are sent to the shortest_path function.
However, the "ROW_NUMBER() OVER (PARTITION BY 1) AS order_tron" instruction, combined with the ORDER BY order_tron shows you how to get an ordered result. This is necessary because there is a join in the external query.
Hope this help,
Christophe DAMOUR (SIGéal)
"Chez Charles"
16480 Saint Laurent des Combes
Téléphone/Télécopie : 05 45 98 36 06
Courriel : sigeal@sigeal.fr
Site : www.sigeal.fr
Le 20/03/2012 13:50, Sven Schroeter a écrit :
I’m playing with Pgrouting using my own routing network (for bicycle) to
navigate from sub-line A to sub-line B:
SELECT rt.gid, AsText(rt.the_geom) AS wkt,
length(rt.the_geom) AS length, routen_sub.id
FROM routen_sub,
(SELECT gid, the_geom
FROM dijkstra_sp_directed(
'routen_sub',
5,
22,
true, true)
) as rt
WHERE routen_sub.gid=rt.gid;
First Question:
This works fine but the result geometry of my direction is unsorted. Is
there a possibility to sort the result directly via SQL?
Second Question:
Is it possible to set a "via" point directly in the SQL? With
dijkstra_sp_directed is it only possible to set a start and a endpoint.
Thanks
Sven
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
