Please post this on the pgrouting list so others can learn from your experience.
What do the follow queries report?
select * from pgr_version();
select version();
Try changing the query to:
select ksp.id1, ksp.id3, n.source, n.target,
round(st_length(n.the_geom)::numeric, 2) as len
from pgr_ksp(
'select source, target, cost,reverse_cost, id from network order by id'::text,
4,
5,
15,
'f'::boolean) ksp,
network n
where ksp.id3=n.id
order by ksp.id1, ksp.id3;
By the way this function is part of pgRouting 2.0 and will not work on version 1.x
-Steve
On 9/25/2013 8:54 AM, Tina Musa wrote:
Hello Steve,
thank you for the help
I loaded data file, it is ok.
I saw the test file, i run the sql query-- Generate 15 shortest paths between nodes 4 and 5
-- List by links
from pgr_ksp(
id',
4,
5,
15,
'f') ksp,
network n
where ksp.id3=n.id
order by ksp.id1, ksp.id3;But it the function pgr_ksp doesn't existed
Who can be the problem?ERROR: function pgr_ksp(unknown, integer, integer, integer, unknown)
does not exist LINE 2: from pgr_ksp( ^ HINT: No function matches the
given name and argument types. You might need to add explicit type
casts. ********** Error ********** ERROR: function pgr_ksp(unknown,
integer, integer, integer, unknown) does not exist SQL state: 42883
Hint: No function matches the given name and argument types. You might
need to add explicit type casts. Character: 77Message: 10
Date: Mon, 23 Sep 2013 09:25:49 -0400
<mailto:woodbri@swoodbridge.com>>
To: postgis-users@lists.osgeo.org <mailto:postgis-users@lists.osgeo.org>
Subject: Re: [postgis-users] k-shortst paths
Message-ID: <5240415D.2080608@swoodbridge.com
<mailto:5240415D.2080608@swoodbridge.com>>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedTina,
you should be asking this question on the Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-usersIf you look in github
https://github.com/pgRouting/pgrouting/tree/master/src/ksp/test
there are tests for all the code, load the *.data file, then look at the
*.test files and you can run them.Docs are here
http://docs.pgrouting.org/See you on the other list.
-Steve
On 9/23/2013 8:57 AM, Tina Musa wrote:
Hello,
I see in pg routing web site that provide Yen algorithm function.
I try to run the algorithm but it's impossible to do.
Can you tell me the steps that i can do to run the algorithm successfully?Thank you in advance
