Hi everyone,
I am wondering, does pgrouting require to have tables on the public schema ? or could they be on any schema ?
Ricardo
Hi everyone,
Ricardo
You can have it in other schemes but you need to run the assign_vertex_id in the public scheme, that is my experience.
/H
Good question, Ricardo!
And thank you for sharing your experience, Henrik.
I must admit I haven’t tried it, and probably the majority of users always works in public schema.
I added a ticket not to forget about this, because I think it would be nice to support the schema in all functions:
https://github.com/pgRouting/pgrouting/issues/issue/24
Daniel
2011/1/28 Henrik Berggren <henke.berggren@gmail.com>
/H
On 01/25/2011 10:42 PM, Ricardo Bayley wrote:
Hi everyone,
Ricardo
_______________________________________________ Pgrouting-users mailing list [Pgrouting-users@lists.osgeo.org](mailto:Pgrouting-users@lists.osgeo.org) [http://lists.osgeo.org/mailman/listinfo/pgrouting-users](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
I also found that I could only use pgrouting with a data table that are in the public schema. My memory is that in some of the functions (I know this is true for the shooting star algorithm), the public schema is “hard wired” within the code. Dan — On Thu, 1/27/11, Daniel Kastl daniel@georepublic.de wrote: > From: Daniel Kastl daniel@georepublic.de > Subject: Re: [pgrouting-users] Table location > To: “pgRouting users mailing list” pgrouting-users@lists.osgeo.org > Received: Thursday, January 27, 2011, 8:18 AM > > Good question, Ricardo! > And thank you for sharing your experience, Henrik. > > I must admit I haven’t tried it, and probably the majority of users always works in public schema. > I added a ticket not to forget about this, because I think it would be nice to support the schema in all functions: > https://github.com/pgRouting/pgrouting/issues/issue/24 > > Daniel > > 2011/1/28 Henrik Berggren henke.berggren@gmail.com > > > You can have it in other schemes but you need to run the assign_vertex_id in the public scheme, that is my experience. > > > > /H > > > > On 01/25/2011 10:42 PM, Ricardo Bayley wrote: > > > > > Hi everyone, > > > > > > I am wondering, does pgrouting require to have tables on the public schema ? or could they be on any schema ? > > > > > > Thanks, > > > > > > Ricardo > > > > > > <br>> > > <br>> > > _______________________________________________<br>> > > Pgrouting-users mailing list<br>> > > Pgrouting-users@lists.osgeo.org<br>> > > [http://lists.osgeo.org/mailman/listinfo/pgrouting-users](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)<br>> > > <br>> > > > > > > _______________________________________________ > > Pgrouting-users mailing list > > Pgrouting-users@lists.osgeo.org > > http://lists.osgeo.org/mailman/listinfo/pgrouting-users > > – > Georepublic UG & Georepublic Japan > eMail: daniel.kastl@georepublic.de > Web: http://georepublic.de > > -----Inline Attachment Follows----- > > _______________________________________________ > Pgrouting-users mailing list > Pgrouting-users@lists.osgeo.org > http://lists.osgeo.org/mailman/listinfo/pgrouting-users |
Are you sure about that the data needs to be in the public schema for shooting_star to work properly?
/Henrik
I decided I needed to clarify the point on the public schema being hard wired. What is really going on is that in a number of the pgRouting functions (implicitly) do not allow the use of other schemas since the code does not allow for the specification of a schema for a table. As a result, only tables in the public schema can be found by the functions.
Dan
Received: Thursday, January 27, 2011, 10:06 AMI also found that I could only use pgrouting with a data table that are in the public schema. My memory is that in some of the functions (I know this is true for the shooting star algorithm), the public schema is “hard wired” within the code.
Dan
Received: Thursday, January 27, 2011, 8:18 AMGood question, Ricardo!
And thank you for sharing your experience, Henrik.I must admit I haven’t tried it, and probably the majority of users always works in public schema.
https://github.com/pgRouting/pgrouting/issues/issue/24Daniel
/H
Hi everyone,
Ricardo
_______________________________________________ Pgrouting-users mailing list Pgrouting-users@lists.osgeo.org [http://lists.osgeo.org/mailman/listinfo/pgrouting-users](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)
http://lists.osgeo.org/mailman/listinfo/pgrouting-users–
Web: http://georepublic.de-----Inline Attachment Follows-----
http://lists.osgeo.org/mailman/listinfo/pgrouting-users-----Inline Attachment Follows-----
This does not really address your question, but I always setup my databases with postgis and pgRouting in public, but ALL my data and procedures ALWAYS get put in another schema like "data".
The reason for this is because, it greatly simplifies doing upgrades to postgis and/or pgRouting AND if I want to clone my setup to another system that might have a different postgis/pgRouting setup loaded on it then I don't run into problems.
pg_dump -N public ....
Will dump everything except "public"
Then I create an new database from a template with postgis and pgRouting already installed and load my data from the dump. And everything is nice and clean and ready to go.
-Steve W
Given your comment on vertex assignments needing to be done in the public schema, I’m now not sure. I may have had a problem with the vertex assignments, looked through that code and discovered that it didn’t handle anything other than the public schema well, and just put everything in public after that. I did this in July, so things are on the hazy side. What I was working on isn’t part of a web application, and I am behind a firewall, so I was safe in keeping everything in the public schema.
Dan
Received: Thursday, January 27, 2011, 10:26 AMAre you sure about that the data needs to be in the public schema for shooting_star to work properly?
/Henrik
Dan
/H
Hi everyone,
Ricardo
http://lists.osgeo.org/mailman/listinfo/pgrouting-users_______________________________________________ Pgrouting-users mailing list Pgrouting-users@lists.osgeo.org [http://lists.osgeo.org/mailman/listinfo/pgrouting-users](http://lists.osgeo.org/mailman/listinfo/pgrouting-users)
I cloned vertex assignment code to change it for zlevels and it was trivial to make it run in another schema. I think all you need to do is:
1. remove all the explicit references to "public." from the stored procedure and reload it in you "data." schema
2. then make sure you set the default db search path like:
alter database mydb set search_path to data, public;
And everything is good.
-Steve
public schema, I'm now not sure. I may have had a problem with the
didn't handle anything other than the public schema well, and just put
the hazy side. What I was working on isn't part of a web application,
public schema.Dan
To: "pgRouting users mailing list" <pgrouting-users@lists.osgeo.org>
for shooting_star to work properly?/Henrik
the public schema is "hard wired" within the code.Dan
--- On *Thu, 1/27/11, Daniel Kastl /<daniel@georepublic.de>
</mc/compose?to=daniel@georepublic.de>/* wrote:From: Daniel Kastl <daniel@georepublic.de>
</mc/compose?to=pgrouting-users@lists.osgeo.org>
And thank you for sharing your experience, Henrik.I must admit I haven't tried it, and probably the majority of
assign_vertex_id in the public scheme, that is my experience./H
Hi everyone,
the public schema ? or could they be on any schema ?Thanks,
Ricardo
Web: http://georepublic.de/>-----Inline Attachment Follows-----
Pgrouting-users@lists.osgeo.org </mc/compose?to=Pgrouting-users@lists.osgeo.org>
Hi Steve,
Have you submitted a patch with the changes? It seems like a good change.
Dan
To: pgrouting-users@lists.osgeo.org
Received: Friday, January 28, 2011, 10:00 AM
need to do is:1. remove all the explicit references to "public." from the
stored
procedure and reload it in you "data." schema2. then make sure you set the default db search path like:
-Steve
done in the
problem with the
discovered that it
well, and just put
so things are on
web application,
everything in the
> public schema.
> Dan
wrote:
> From: Henrik Berggren <henke.berggren@gmail.com>
Table location
27, 2011, 10:26 AM
properly?
> /Henrik
>> Dan
wrote:
>> From: Daniel
>> Subject: Re:
>> To:
>> Received:
>> Good
question, Ricardo!
>> And thank
>> I must admit
>> users always
>> I added a
>> would be
>> Daniel
>> 2011/1/28
need to run the
/H
wrote:
Hi everyone,
have tables on
any schema ?
Ricardo
>> Georepublic
>> -----Inline
list
Follows-----
On 1/29/2011 12:36 PM, Dan Putler wrote:
Hi Steve,
Nope, I never got around to patches, but after looking into the problem again, I may have been mistaken. The only place that 'public' is explicity used is in "core/sql/routing_topology.sql" in:
_srid := Find_SRID('public','vertices_tmp','the_geom');
And this should be ok, unless you move the location of 'vertices_tmp' to another schema.
I have rewritten a lot of the wrapper code for my own purposes and it might not be general purpose anymore.
For example in the piece above, I moved the query query for srid out of point_to_id() into assign_vertex_id() and use the code:
EXECUTE 'SELECT srid FROM geometry_columns WHERE f_table_name='|| quote_ident(geom_table) INTO srid;
Then I pass the srid into point_to_id() because the srid should not change from point to point. And while psql probably caches the query, there is no need to compute it multiple times.
As some point when I have some spare time I will review my code changes and propose a set a patches back to the source tree. One of the other big changes I made for my purposes, was to rationalize the the wrapper API calls so that they are nearly identical except for the name. This makes if much easier to write generic code from an application point of view there you only need to change the function name to change the analysis getting done. Otherwise you have to basically code multiple paths to setup for the different functions as they now stand.
Part of the motivation for this was writing the driving directions code so it had mimimal impact on the code when changing the analysis method between dijkstra, astar and shootingstar.
-Steve
Dan
stored
-Steve
done in the
problem with the
discovered that it
well, and just put
so things are on
web application,
everything in the
public schema.
Dan
wrote:
Subject: Re: [pgrouting-users]Table location
list"<pgrouting-users@lists.osgeo.org>
27, 2011, 10:26 AM
properly?
/Henrik
Dan
wrote:
Kastl<daniel@georepublic.de>
Subject: Re:
To:
Received:
Good
question, Ricardo!
And thank
I must admit
users always
I added a
would be
Daniel
2011/1/28
Henrik Berggren<henke.berggren@gmail.com>
need to run theassign_vertex_id in the public scheme,
wrote:Hi everyone,
have tables onthe public schema ? or could they be on
any schema ?Thanks,
Ricardo
GeorepublicUG& Georepublic Japan
list
Follows-----
2011/1/30 Stephen Woodbridge <woodbri@swoodbridge.com>
Hi Steve,
Nope, I never got around to patches, but after looking into the problem again, I may have been mistaken. The only place that ‘public’ is explicity used is in “core/sql/routing_topology.sql” in:
_srid := Find_SRID(‘public’,‘vertices_tmp’,‘the_geom’);
And this should be ok, unless you move the location of ‘vertices_tmp’ to another schema.
Yes, I thought about this as well. I think, this hasn’t changed since it pgRouting was named pgDijkstra long time ago.
Without going through the code I would assume that wrapper functions like shooting_star_smart might be affected as well.
But wrappers were seen more as examples how to write your own functions in the beginning, so they were supposed to be modified by users as you are doing.
As I already said before. Though it seems having samples available for others to learn from is a huge help.
This is something I would like to discuss in the near future.
I think we could try to make function names a bit more consistent as they are now.
Having some conventions or a naming schema here would make it easier.
Good proposals are welcome!
Right. I even thought about passing the algorithm name as the first parameter for example and have then one function called shortest_path for example.
Daniel
-Steve
Dan
need to do is:
remove all the explicit references to “public.” from the
stored
procedure and reload it in you “data.” schemathen make sure you set the default db search path like:
-Steve
done in the
problem with the
discovered that it
well, and just put
so things are on
web application,
everything in the
public schema.
Dan
— On Thu, 1/27/11, Henrik Berggren /<henke.berggren@gmail.com>/
27, 2011, 10:26 AM
properly?
/Henrik
Dan
— On *Thu, 1/27/11,
Subject: Re:
To:
Received:
Good
question, Ricardo!
And thank
I must admit
users always
I added a
would be
Daniel
2011/1/28
wrote:Hi everyone,
any schema ?Thanks,
Ricardo
Web: http://georepublic.de<http://georepublic.de/>-----Inline
list
Follows-----
