I began playing around with the TSP functions in pgrouting (v1.0.5) and came into some problems.
Guess the first question to ask is what is the current state of the TSP algorithms?
Second, the problem I ran into was when running the tsp function… tsp(sql text, ids character varying, source integer)
…anytime I ran it it would disconnect my session from postgresql.
The next thing I tried was to try running tsp_dijkstra(geom_table character varying, ids character varying, source integer)
Here I got the error “relation “tsp_test” does not exist”. Apparently “tsp_test” is a table, but I can’t find anything on what it is supposed to contain.
Can anyone help with a little direction on how to get through these problems?
Thanks!
Hi List
I am trying to use the traveling sales map support functions.
They all seem to require the setup of a support table called tsp_test
Has there been any follows up to Steves email on this subject
algorithms?
Second, the problem I ran into was when running the tsp function...
tsp(sql
..anytime I ran it it would disconnect my session from postgresql.
character
Here I got the error "relation "tsp_test" does not exist". Apparently
"tsp_test" is a table, but I can't find anything on what it is supposed to
contain.
problems?
Thanks!
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
It seems that tsp_test should be a clone of your route table.
The existing code requires a table with a reverse_cost, target,source and
geom of type lineString.
Dave Potts wrote:
Hi List
algorithms?
tsp(sql
character
to
contain.
problems?
Thanks!
