Hi Steve,
Normally trsp gives back the shortest route as an ordered list of
ways, let's say A, B, C, D, E.
The problem is trsp was giving back, for a specific set of data, the
shortest route in a random order: C, D, A, E, B.
I found out what was causing this problem, so I post it here to help
people with the same problem.
The problem was not with trsp, but with postgresql.
This was my original SQL query:
SELECT * FROM turn_restrict_shortest_path('#{query}',#{source_id},
#{target_id}, true, true, '')) JOIN #{table_name} ON edge_id = id;
The problem was caused by the JOIN operation. Without the JOIN, the
route was in the correct order, but the JOIN altered it. I'm not an
SQL expert, so I don't know why this was happening in only this case.
The original query above was working fine with the other tables.
Anyway, this is what I did to solve the problem:
WITH route AS (SELECT ROW_NUMBER() OVER (PARTITION BY 1) as rank, *
#{target_id}, true, true, '')) SELECT * FROM route JOIN #{table_name}
ON edge_id = id ORDER BY RANK;
I created a column with the number of the row, and reordered it back
after the JOIN. I read somewhere that this fix was used to solve a
similar problem (sorry, don't have the link).
Best regards,
Tao
2013/6/5 Stephen Woodbridge <woodbri@swoodbridge.com>:
On 6/4/2013 10:42 AM, Tao Romera Martinez wrote:
Dear all,
We have been using the trsp function for a while now, and yesterday we
had strange results for the first time: the shortest route given as
result was in total disorder.
Hi Tao,
Can you explain more exactly what you mean by "result was in total
disorder"?
I hear something is not as you would expect it, but I'm not sure exactly
what is wrong.
-Steve
We work with the OpenStreeMap dataset for the whole planet, but we
have it split in countries. Thus, we have a table with the routable
network for France, one for Japan, etc. trsp has been working nicely
for a bunch of countries, but yesterday someone tried our app
(SweetWay, for iPhone, as a matter of fact) from Bahrain for the first
time, and by checking the results I realized the route was in total
disorder. I was puzzled, because the function has worked without
problems so far in many other countries.
Has anyone experienced this problem before? I made some research with
Google, but couldn't find anything relevant.
Thanks for your help,
Tao
Tao Romera Martínez
Tel: 080-6805-0945
Address: Koganei-shi, Tokyo, Japan
Look for me on Facebook and LinkedIn
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Tao Romera Martínez
Tel: 080-6805-0945
