Ross,
Thanks for the catch about 2.0. I forgot to flip the labeling and that’s pointing at develop which has since been flipped to 2.1 branch. I’ll fix that.
Regarding RCs. Yes will be packaging those later this week so should be available Monday. But sounds like you already have it
Unfortunately I won’t be packaging 2.1 for PostgreSQL 9.2 as installer, but the binaries will be available at release time.
Only reason for that is that the pgRouting 2.1.0 will be available with PostGIS 2.2 installers, and I’m planning to drop 9.2 for PostGIS 2.2.
Regina
From: pgrouting-users-bounces@lists.osgeo.org [mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of McDonaldR
Sent: Wednesday, August 19, 2015 9:37 AM
To: ‘pgRouting users mailing list’ pgrouting-users@lists.osgeo.org
Subject: Re: [pgrouting-users] TRSP error - Invalid result geometry node_id:-1edge_id:0
OK, testing on Windows 7 64bit with the following setups confirms your fix:
Testing with PostGIS 2.1.8 and pgRouting 2.0.0
“PostgreSQL 9.4.4, compiled by Visual C++ build 1800, 64-bit”
“POSTGIS=“2.1.8 r13780” GEOS=“3.4.2-CAPI-1.8.2 r3924” PROJ=“Rel. 4.8.0, 6 March 2012” GDAL=“GDAL 1.11.1, released 2014/09/24 GDAL_DATA not found” LIBXML=“2.7.8” LIBJSON=“UNKNOWN” TOPOLOGY RASTER”
“2.0.0”;“pgrouting-2.0.0”;“0”;“f26831f”;“master”;“1.53.0”
TRSP returns route not found
“PostgreSQL 9.3.9, compiled by Visual C++ build 1600, 64-bit”
“2.0.0”;“pgrouting-2.0.0”;“0”;“d6ed2cb”;“master”;“1.53.0”
“PostgreSQL 9.2.13, compiled by Visual C++ build 1600, 64-bit”
Testing with PostGIS 2.2.0dev and pgRouting 2.1.0alpha and rc1
“POSTGIS=“2.2.0dev r13937” GEOS=“3.5.0-CAPI-1.9.0 r4088” PROJ=“Rel. 4.9.1, 04 March 2015” GDAL=“GDAL 2.0.0, released 2015/06/14 GDAL_DATA not found” LIBXML=“2.7.8” LIBJSON=“0.12” TOPOLOGY RASTER”
“(2.1.0,pgrouting-2.1.0-rc1,81,5fa89b2,develop_2_1_0,1.58.0)”
TRSP returns a valid route
“(2.1.0,pgrouting-2.1.0-alpha1,81,5fa89b2,develop_2_1_0,1.58.0)”
Is there a RC1 for PG9.2.x?
I also noticed the zipped binaries at http://winnie.postgis.net/download/windows/pg94/buildbot/pgrouting-pg94-binaries-2.0w64gcc48.zip are labelled as 2.0 but is actually the 2.1.0 RC1
Thanks
Ross
From: pgrouting-users-bounces@lists.osgeo.org [mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of Paragon Corporation
Sent: 18 August 2015 19:11
Ross,
The true test would be testing on 64-bit Windows.
As I recall when I was doing the debugging of this problem, the issue did not happen under windows 32-bit. It only happened under windows 64-bit.
As KoNagase mentioned we made changes to make it work in pgRouting 2.1.0, but the underlying issue is not fixed. Which is what is meant by "fixed temporary"
As a general precaution – in windows 64-bit – it only works if you have NOTICE enabled either for logging or client messages – which is the default, so should work for most folks.
We will investigate the issue more for the 2.0.1 and 2.1.1 releases.
Regina
Sent: Tuesday, August 18, 2015 11:28 AM
To: ‘pgRouting users mailing list’ <pgrouting-users@lists.osgeo.org>
Regina,
Using the 2.1.0 version [“2.1.0”;“pgrouting-2.1.0-alpha1”;“81”;“5fa89b2”;“develop_2_1_0”;“1.58.0”] on my Windows 7 32bit PC the problem is indeed fixed.
TRSP works with and without reverse costs, with and without turn restrictions and with both vertices and edges.
Huge thanks to you, Steve, Ko and Vicky (and others) for all the work that goes into making pgRouting better and better. It is much appreciated. I am going to be running a couple of short training sessions using pgRouting shortly after showing a couple of live examples at our internal GIS user group that piqued interest.
Ross
Sent: 18 August 2015 14:29
Ross,
Were you able to try the 2.1.0 beta binaries?
This issue should be fixed on those.
Regina
Sent: Tuesday, August 18, 2015 8:53 AM
To: pgrouting-users@lists.osgeo.org
Subject: [pgrouting-users] TRSP error - Invalid result geometry node_id:-1edge_id:0
Hello list
I am getting an error using the pgr_trsp function with vertices.
[Invalid result geometry node_id:-1 edge_id:0] using the pgRouting Layer plugin in QGIS
The query is:
SELECT *
FROM pgr_trsp('SELECT gid as id, source::integer, target::integer, cost_len::float AS cost
FROM itn_network’,
30,
60,
false,
false
Result
0;-1;0;0 using PgAdmin
If I use the function with edges then it works as expected
SELECT *
FROM itn_network’,
2958, 0.5,
1194, 0.5,
false,
false
Result
0;-1;2958;302.909919799321
1;21;12;3289.06571781744
2;22;2534;0
3;1841;1484;0
4;1063;669;657.261388446325
5;1062;671;306.606908032689
6;1064;2381;0
7;428;241;0
8;427;69391;0
9;1504;1104;0
10;1069;675;0
11;1066;672;0
12;430;242;0
13;429;1763;0
14;506;290;814.718952140309
15;507;1157;206.661904345321
16;505;69401;394.173213311315
17;2093;69400;1152.8033703581
18;24;1156;0
19;1109;712;911.407628015424
20;1110;69367;82.6836380428031
21;2275;2954;55.7924940561552
22;2818;69406;10.2909471381108
23;2262;2171;93.7878062207647
24;1548;1148;0
25;1547;1543;0
26;1901;2178;0
27;1546;2172;0
28;1897;1540;0
29;1542;1968;22.2622766251952
30;495;284;0
31;494;2612;0
32;499;286;0
33;498;69364;0
34;1557;1155;0
35;1556;1154;0
36;1555;2603;0
37;146;79;0
38;145;1981;35.7573399535413
39;148;80;0
40;147;2994;0
41;2842;2996;0
42;26;14;0
43;25;1170;0
44;1572;2993;0
45;1133;736;0
46;1132;737;0
47;1134;1173;0
48;1136;739;0
49;150;82;1139.31607861894
50;151;1175;267.426016400421
51;1197;794;0
52;604;349;0
53;603;2077;0
54;1941;1589;0
55;1604;1206;0
56;1196;793;0
57;1195;1207;0
58;1189;788;491.087128220612
59;1190;789;300.17025240827
60;1191;1586;122.598743787454
61;167;1840;0
62;171;92;0
63;170;1579;0
64;1593;1199;0
65;1592;68167;0
66;1183;1828;0
67;1933;1578;0
68;1932;1985;0
69;1595;1200;0
70;1594;1984;26.9342460479565
71;1931;1577;67.4166151627323
72;1181;782;312.414537400116
73;1179;781;0
74;1180;68143;0
75;591;341;0
76;590;772;0
77;1167;68151;0
78;1170;773;0
79;1169;774;0
80;1171;1194;0
Any suggestions on how to debug this? Using the same two vertices with the Djikstra functions works fine.
I am running it on Postgresql 9.2.13 64bit with PostGIS 2.1.7 and pgRouting 2.0.0
“POSTGIS=“2.1.7 r13414” GEOS=“3.4.2-CAPI-1.8.2 r3924” PROJ=“Rel. 4.8.0, 6 March 2012” GDAL=“GDAL 1.11.1, released 2014/09/24” LIBXML=“2.7.8” LIBJSON=“UNKNOWN” TOPOLOGY RASTER”
Thanks
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr@angus.gov.uk
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
