Hello List,
First of all I'd like to say thanks to the pgrouting Team for this great project.
I've build pgrouting with patch: https://github.com/pgRouting/pgrouting/pull/49
It works fine, but only in case when source and destination are different points.
My aim is to solve TSP problem, when start and end point are the same.
Any help would be appreciated.
Best regards,
Darek
On 3/5/2012 6:00 AM, Dariusz Gorski wrote:
Hello List,
The patch was for specifying a separate end point. But according to the thread on the link above, just leave off the last parameter and it should work as before. where you give it a list of ids that you want it to visit and the source_id for the start which is also the end.
-Steve
W dniu 2012-03-05 15:15, Stephen Woodbridge pisze:
Hello List,
First of all I’d like to say thanks to the pgrouting Team for this great project.
I’ve build pgrouting with patch: https://github.com/pgRouting/pgrouting/pull/49
-Steve
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Steve, thanks for your reply.
I’ve tried it before, but even when I use standard TSP functions,
e.g. SELECT * FROM tsp_dijkstra(‘ways’,‘552,272,169,784,1567,314’,272);
I don’t get the loops (attached image).
This is the reason why I thought that in TSP functions only starting point is fixed, but endpoint calculates TSP solver.
According to your hint, where source = destination, I would expect to receive loop.
In my case it does not work in this way.
What am I doing wrong or what am I missing?
Darek
What happens if you do not include the the start node in the list of stops? For example:
SELECT * FROM tsp_dijkstra('ways','552,169,784,1567,314',272);
I have not used this function in pgRouting so I don't know what to expect.
-Steve
Hello List,
great project.
different points.
-Steve
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.osgeo.org>
I've tried it before, but even when I use standard TSP functions,
e.g. SELECT * FROM tsp_dijkstra('ways','552,272,169,784,1567,314',272);
I don't get the loops (attached image).
receive loop.
Darek
If I do not include the start node in the list of stops, I'll get an error:
" The connection to the server was lost. Attempting reset: Failed."
I'm using Ubuntu Server 11.10, PostgreSQL 9.1.3, Postgis 1.5.3, pgrouting 1.05 with patch
https://github.com/sanak/pgrouting/commit/6ec1672f79f7070c60fb6095342d7d0b55cf2659
Inside TSP warappers I've changed "tsp_test" to " ' || quote_ident(geom_table) || ' " in order to get them to work.
Darek
W dniu 2012-03-05 19:03, Stephen Woodbridge pisze:
-Steve
Hello List,
great project.
different points.
-Steve
receive loop.
Darek
Ok, that is not good. Please write a bug ticket for this and a separate bug for the fact that it does not create a loop.
In the short term you can work around the loop problem knowing that you do not have a closed loop and issuing a separate request from the last point to the start point, but this should not be required in my opinion.
Please write this up as another bug. Hopefully if we have tickets on this stuff we can clean up a lot of these issues in the next release when ever that happens.
-Steve
Darek
stops? For example:
expect.
-Steve
Hello List,
great project.
different points.
-Steve
receive loop.
Darek
Steve, thank you for your help.
I’ve created issues with mentioned bugs on GitHub.
W dniu 2012-03-05 19:52, Stephen Woodbridge pisze:
If I do not include the start node in the list of stops, I’ll get an error:
Looking at the results of TSP function, I do not think that order of visited points is correct to make of them a closed loop. In my opinion TSP solver does not assume that the source_id for the start is also the end.
I hope that someone will be able to solve this problem.
Best regards,
Darek
I had come accros this problem as well.
If you do not include the source/target in the list of nodes, you get a
core dump in the server process.
error:
-Steve
Darek
stops? For example:
expect.
-Steve
Hello List,
great project.
different points.
same.
it
-Steve
e.g. SELECT * FROM
receive loop.
Darek
