I’m a new user of linux, I try to install pgrouting from https://launchpad.net/~georepublic/+archive/pgrouting-unstable using my terminal. There are no problem when I installed the osm2pgrouting and cmake package, but when I try to install the pgrouting package the message always same “Unable to Locate Package”. I already checked my sources.list and make sure that line
deb [http://ppa.launchpad.net/georepublic/pgrouting-unstable/ubuntu](http://ppa.launchpad.net/georepublic/pgrouting-unstable/ubuntu) raring main is checked.
Is there anything wrong with my Ubuntu? I'm using Ubuntu 13.04 amd64
Last night I had to rebuild the packages in the pgrouting-unstable
repository because there was a problem with the package for 12.04.
So maybe you were just unlucky and there was the package change right that
time ... though I guess it's a different problem.
Personally I'm using 13.04 and I have no problems to install and upgrade it.
Can you make sure that:
- You also added the UbuntuGIS Launchpad repository to install PostGIS
2.0
- You're looking for the right package name "postgresql-9.1-pgrouting"
- You have run apt-get update to get the latest package list
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
