Currently I was able to install and import osm data into a routing database. I can draw the shortes route using Quantum GIS using a query. But in the workshop website it tells us to create a server side script. We do not have to create it since the workshop folder already has it. But it is not working when I try to run the browser client called routing-final.html file. Only the map is shown path is not drawn when I put two markers.
I also noticed that there is a pgrouting-build and workshop-build folders in the git hub project. But this “workshop-build” does not contain the old php “server side script”. Is this workshop-build is compatible with the old workshop or is this workshop-build only compatible with pgrouting-build?
I just want to display the shortest path in the website. Please help me with this problem.
in the workshop website it tells us to create a server side script<http://workshop.pgrouting.org/chapters/php_server.html>\.
two markers.
in the git hub project. But this "workshop-build" does not contain the old
php "server side script". Is this workshop-build is compatible with the old
with this problem.
The problem with the "old" current workshop is, that it is not working with
pgRouting 2.0 and probably not working with PostGIS 2.0
Though the workshop will be updated for FOSS4G 2013 in September. Then it
will not work anymore for pgRouting 1.05.
So right now it's probably confusing, but it's difficult to support both
versions at the same time.
Currently the priority is to release a stable version of 2.0, so the
workshop will not work for some people until September.
I'm sorry for that, but my personal time is limited. Contributions to fix
it are welcome. Or if you can provide some funding, then it can also be
done faster.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
