Ok, so using what I think is the correct SQL syntax, I get a different sort of error:
eligibility=# SELECT the_geom FROM driving_distance(‘edges’, 2512140, 7040129, 2000, ‘length’, ‘length’, false, false);
NOTICE: SRID: 2276
NOTICE: Query: SELECT gid, the_geom FROM points_as_polygon(‘SELECT a.vertex_id::integer AS id, b.x1::double precision AS x, b.y1::double precision AS y FROM driving_distance(’‘’‘SELECT gid AS id,source::integer,target::integer, length::double precision AS cost, length::double precision as reverse_cost FROM edges WHERE setsrid(’‘’‘’‘’‘BOX3D(2510140 7038129, 2514140 7042129)’‘’‘’‘’‘::BOX3D, 2276) && the_geom ‘’’‘, (SELECT id FROM find_node_by_nearest_link_within_distance(’‘’‘POINT(2512140 7040129)’‘’‘,200,’‘’‘edges’‘’‘)),2000,true,true) a, (SELECT * FROM edges WHERE setsrid(’‘’‘BOX3D(2510140 7038129, 2514140 7042129)’‘’‘::BOX3D, 2276)&&the_geom) b WHERE a.vertex_id = b.source’)
ERROR: function find_node_by_nearest_link_within_distance(unknown, integer, unknown) does not exist
LINE 1: …)‘’::BOX3D, 2276) && the_geom ‘, (SELECT id FROM find_node_…
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
QUERY: SELECT a.vertex_id::integer AS id, b.x1::double precision AS x, b.y1::double precision AS y FROM driving_distance(‘SELECT gid AS id,source::integer,target::integer, length::double precision AS cost, length::double precision as reverse_cost FROM edges WHERE setsrid(’‘BOX3D(2510140 7038129, 2514140 7042129)’’::BOX3D, 2276) && the_geom ', (SELECT id FROM find_node_by_nearest_link_within_distance(‘POINT(2512140 7040129)’,200,‘edges’)),2000,true,true) a, (SELECT * FROM edges WHERE setsrid(‘BOX3D(2510140 7038129, 2514140 7042129)’::BOX3D, 2276)&&the_geom) b WHERE a.vertex_id = b.source
CONTEXT: PL/pgSQL function “points_as_polygon” line 17 at FOR over EXECUTE statement
PL/pgSQL function “driving_distance” line 25 at FOR over EXECUTE statement
Still puzzling this one out.
On Tue, Dec 21, 2010 at 7:55 PM, Roger André <randre@gmail.com> wrote:
Hi Daniel,
Thanks for your reply. I checked, and it appears that I have that wrapper function installed. Here is what my pgrouting install dir looks like:
$ pwd
/usr/local/pgrouting-1.05/extra/driving_distance/sql
$ ll
total 36
drwxr-xr-x 3 15036 users 4096 2010-12-21 15:58 ./
drwxr-xr-x 5 15036 users 4096 2010-12-21 15:58 …/
drwxr-xr-x 2 root root 4096 2010-12-21 15:58 CMakeFiles/
-rw-r–r-- 1 root root 1811 2010-12-21 15:58 cmake_install.cmake
-rw-r–r-- 1 15036 users 134 2010-11-16 18:42 CMakeLists.txt
-rw-r–r-- 1 root root 5540 2010-12-21 15:58 Makefile
-rw-r–r-- 1 15036 users 1757 2010-11-16 18:42 routing_dd.sql
-rw-r–r-- 1 15036 users 3790 2010-11-16 18:42 routing_dd_wrappers.sql
And I did make sure to run both SQL files against the database my roads are stored in.
482 psql -d eligibility -f routing_dd.sql
483 psql -d eligibility -f routing_dd_wrappers.sql
490 psql -d eligibility -f routing_tsp.sql
491 psql -d eligibility -f routing_tsp_wrappers.sql
I will review your usage instructions and see if I’m missing anything.
Roger
On Tue, Dec 21, 2010 at 5:51 PM, Daniel Kastl <daniel@georepublic.de> wrote:
Hi Roger,
You’re using the “core” function, I think.
You could use the driving_distance wrapper function, which will return you a polyogon.
For that you need to load this SQL: https://github.com/pgRouting/pgrouting/blob/master/extra/driving_distance/sql/routing_dd_wrappers.sql
You can also find it in the directory where the other pgRouting SQL files are.
The function will take these parameters then:
driving_distance(table_name varchar, x double precision, y double precision,
distance double precision, cost varchar, reverse_cost varchar, directed boolean, has_reverse_cost boolean)
X,Y are the coordinates you take as a center point.
You can take the returned polygon then and do other spatial queries.
Best regards,
Daniel
2010/12/22 Roger André <randre@gmail.com>
Hi All,
I need to generate some maps that show all of the road segments that are within a certain distance of specific points. I have been able to generate some answers using the driving_distance function, but am not sure what to do with them. Here’s what I get:
SELECT * FROM driving_distance(‘SELECT gid AS id, source, target, length::double precision AS cost FROM edges’,49,2000,false,false);
vertex_id | edge_id | cost
15 | 9 | 1854.34547361565
20 | 104 | 1549.85630678904
22 | 68 | 858.367668935802
23 | 125 | 1466.02479201359
24 | 75 | 801.137871846872
25 | 125 | 1169.02817170106
26 | 106 | 1296.98197602289
48 | 71 | 902.595810873304
49 | 106 | 0
51 | 74 | 1948.07551810288
52 | 75 | 1620.93404864578
(11 rows)
These answers seem legit, but I’m not sure what to do with them. Ultimately, I need to show both the minimum enclosing polygon that “surrounds” all of the road segments, as well as the road segments themselves. Can someone please give me some pointers as to what I can do to accomplish this?
Roger
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
