I've tried to make this example of how the wrong edge is chosen, as
simple as possible:
drop table if exists edge;
CREATE TABLE edge (
id int4,
source int4,
target int4,
cost float8,
reverse_cost float8);
truncate edge;
insert into edge values ( 2, 1, 2, 2, 2);
insert into edge values ( 1, 1, 2, 1, 1);
SELECT * FROM shortest_path('SELECT * from edge', 1, 2, true, true);
# Choses the longer route:
vertex_id | edge_id | cost
1 | 2 | 2
2 | -1 | 0
(2 rows)
If I change the order of the inserts it gets the right answer.
I think this bug is related to
http://pgrouting.postlbs.org/ticket/177
Simon
