PlanetX is a free open source (GPL 3) plugin for QGIS 3.36 and newer, QGIS 4 included. It opens a 3D globe in its own window next to the QGIS map and shows the whole Earth from space down to single streets.
- QGIS project layers on the globe in the map order, a swipe to compare layers, map and globe synchronization in any CRS.
- Terrain with vertical exaggeration, atmosphere, sun lighting by time, OSM base map and 3D buildings.
- My Places - placemarks, paths and polygons, KML and KMZ import and export, tours with MP4 recording.
- Ruler on the WGS84 ellipsoid, elevation profile, slope, aspect, viewshed, insolation, flooding and water flow.
- Point clouds (LAS, LAZ, COPC through PDAL), own terrain from a project raster, drill holes and tunnels under the surface.
- Geology and geophysics layers, earthquakes, Earth cutaway, map sheet designations.
- Other bodies - the Moon, Mars, Jupiter moons and more, and the starry sky.
- PlanetX Lite is the same globe without QGIS - one Rust program for Windows, Linux and macOS and the same program as a web page. It opens scenes saved by the plugin, KML/KMZ, tours, point clouds and 3D models. Version 0.22.0 opens GeoPackage, Shapefile, GeoJSON, GPX, GML, MapInfo, FlatGeobuf, DXF and DWG as layers with styles, labels and extrusion. License Apache 2.0.
- The plugin prepares scenes, Lite shows them on any computer or phone.
- Plugin in the QGIS repository: https://plugins.qgis.org/plugins/planetx/
- PlanetX Lite in the browser and downloads: PlanetX Lite
- Questions and wishes are welcome.
PlanetX 1.40 for QGIS - site analysis as one toolkit. What should come next?
Six recognition windows are merged into one Recognition window. The source is Sentinel-2 images (the window picks a summer image and a snow image itself), the globe base map, a project raster or AlphaEarth embeddings. Tasks - own samples, image colors, similar to a sample, forests and clear-cuts, fields, water, overgrown fields. OK puts a class raster and smoothed polygons into the project, the forest, field and water tasks also give center lines of roads, rivers and cuttings.
The same Site analysis submenu has slope and aspect, viewshed with buildings, insolation and shadows, flooding, flow lines and catchments, sea level, land change 2017-2025, minerals by spectrum and EMIT, earthworks. All data are open and free.
What next? Options - class accuracy and an error matrix, image time series over years, Sentinel-1 radar, batch runs over layer polygons, own class rules, a site report - or simplify. Examples of your own tasks are most welcome.
Release and manual - Release PlanetX 1.40.0 · Valery35/planetx · GitHub
Plugin - https://plugins.qgis.org/plugins/planetx/
PlanetX Lite 0.23.0 follows the plugin 1.40.
- One Recognition window instead of Classification, Object extraction, Tracing and Similar areas. Tasks - own samples, image colours, similar to the sample, forests and clearcuts, fields, water, overgrown fields. The source of own samples - Sentinel-2 images of the area, the globe basemap, an opened raster or AlphaEarth.
- “OK” puts smoothed class polygons into My layers, which now stay between launches, gather in folders and export to GeoJSON.
Release: Release PlanetX Lite 0.23.0 · Valery35/planetx-lite · GitHub
Bugs and wishes: Sign in to GitHub · GitHub
PlanetX 1.41 for QGIS - open national maps on the globe.
The Base maps catalog adds the TopPlusOpen world map, basemap.de of Germany, swisstopo maps and SWISSIMAGE aerial photos of Switzerland, PDOK maps and aerial photos of the Netherlands. Around the country and from afar the globe shows an Esri base map, so the world around stays filled. Map overlays add Waymarked Trails mountain bike and riding routes and ski slopes.
Release and manual - Release PlanetX 1.41.0 · Valery35/planetx · GitHub
PlanetX 1.42 for QGIS - smaller labels from afar and a shared scene format.
Place names on the globe get smaller from afar - full size up to 300 km, 70 percent at 6000 km, with as many labels in the frame as before. A scene keeps the base map key, so PlanetX Lite and rustPlanetX open a plugin scene with the same base map. A scene with own point icon pictures is saved together with the pictures. The plugin page now has a Video section.
Release and manual - Release PlanetX 1.42.0 · Valery35/planetx · GitHub
Plugin - PlanetX — QGIS Python Plugins Repository
PlanetX Lite 0.24.0 - 3D Tiles by a link, My layers as a panel section and a scene shared with the PlanetX plugin for QGIS 1.42.
A 3D Tiles set opens by a link from the search line, from a tileset.json file or a ZIP archive. Pieces load as the camera comes closer, Draco and meshopt compression is read. My layers is a panel section of its own, like the QGIS project in the plugin, and the results of the analysis windows come there. The Add data window has sections and row previews. Water mixes with the imagery as in the plugin, and low land such as the Caspian Depression stays dry. The scene follows the common format of the PlanetX line, so the plugin and Lite open it the same way.
Release - Release PlanetX Lite 0.24.0 · Valery35/planetx-lite · GitHub
PlanetX Lite 0.25.0 - open national maps, three more trail overlays and the surface temperature, as in the PlanetX plugin for QGIS 1.41 and 1.42.
The base maps add TopPlusOpen of the world, basemap.de of Germany, swisstopo maps and SWISSIMAGE aerial photos of Switzerland, PDOK maps and aerial photos of the Netherlands. A national map is shown inside its country, around it and from afar the globe shows an Esri map or imagery. Map overlays add Waymarked Trails mountain bike routes, ski slopes and riding routes. The Surface temperature row shows the land temperature from MODIS and the sea temperature from GHRSST MUR, NASA GIBS data. The base maps and overlays of Lite are checked against the common source catalog of the PlanetX line, so the plugin and Lite show the same maps.
Release - Release PlanetX Lite 0.25.0 · Valery35/planetx-lite · GitHub
RustPlanetX 0.5.2 - the PlanetX 3D globe for RustGIS, a free desktop GIS written in Rust. The plugin links the globe with the RustGIS map, as the PlanetX plugin links it with QGIS.
- The layers of the RustGIS project are listed in the RustGIS project section of the globe. A check puts a layer on the globe in the colours of its RustGIS style, rasters and tile layers keep their look from the map.
- The layer menu zooms to the layer and sets its opacity, labels and extrusion.
- The globe follows the map, and the map follows the globe.
- A feature picked on the globe is selected in RustGIS, and a globe layer goes to the RustGIS project.
- Terrain, imagery, site analysis, tours and KML come from PlanetX Lite.
Install in RustGIS 0.5.0 or newer - Plugins › Plugin Manager › Settings › Install From File…, the file rustplanetx-0.5.2.rgplugin. The package is for Windows.
Release - Release v0.5.2 · Valery35/rustplanetx · GitHub
PlanetX Lite 0.26.0 - JAXA Earth satellite data by month and I3S scene layers of ArcGIS by a link.
The Add data window gets seven JAXA Earth rows. They are land and sea surface temperature, the NDVI vegetation index, chlorophyll-a in the sea, GSMaP precipitation, soil moisture and aerosol optical depth. Each row is a monthly mean for the whole world on a 0.1° grid with its own scale. The month is set by the time slider. An I3S scene layer opens by a link to an ArcGIS SceneServer service from the search line. Buildings and meshes of 3D Object and Integrated Mesh layers load as the camera comes closer, like 3D Tiles sets.
Desktop program for Windows, Linux and macOS and the web page - PlanetX Lite
Release - Release PlanetX Lite 0.26.0 · Valery35/planetx-lite · GitHub
