Pom.xml question: project.version or gs.version guidance?
I have been building random community modules as I backport some fixes from GeoServer 3.0.0-SNAPSHOT.
And I have a question - what is preferable to use?
Use project.version:
    <dependency>
      <groupId>org.geoserver.community</groupId>
      <artifactId>gs-web-dggs</artifactId>
      <version>${project.version}</version>
    </dependency>
Or use gs.version:
    <dependency>
      <artifactId>gs-web-ogcapi</artifactId>
      <version>${gs.version}</version>
    </dependency>
Some community “assembly” pom.xml` files have both…
The property gs.version is defined in the root pom.xml and I cannot think of a reason this would ever not match project.version? It primarily seems to be used in assembly modules.
Is it okay to get rid of gs.version or does it have a use I cannot figure out?
the root pom uses ${gs.version} extensively in dependencyManagement as well, there might be a catch where this cannot be ${project.version} for Maven resolver reasons… my memory is vague on that
A quick way to check/validate might be to replace <gs.version>3.0.0-SNAPSHOT</gs.version> with <gs.version>${project.version}</gs.version>
The two settings are redundant, I expect it may be from community modules developed independely and then donated to the geoserver repo?
Here is a PR to test removing gs.version:
In our project, we also have that redundancy long time ago, but someone left this comment:
<!-- This redundant version definition is important to simplify solution inheritance -->
    <nw.version>${project.version}</nw.version>
We have a product, that some customization solutions can depend on.
Probably this is old code style, because today the inheritance is through a separated BOM and not the root pom.
:face_with_peeking_eye:
