I am using grass4.1.5 on linux (slack 3.0, k1.2.13).
i am trying to generate some post script plots, but
get a segmentation fault when I try to run ps.map. I
have the ps drivers configured and selected correctly. I am
also getting a floating point excpetion error on a machine running
grass4.1.3 (slack 2.3, k1.2.8). It has no coprocessor,
but has floating point emulation enabled in the kernel...
Did you get the segmentation fault error every time? Has anyone had the same
error with the Linux GRASS 4.15 binaries that available on moon?
I had the same problem with GRASS 4.15 binaries from moon.
I run the Kernel 1.3.70 (elf).
Wang Zhong Min
Laboratory of Hydrology
Free University Brussels
Pleinlaan 2, 1050 Brussels
Belgium
zhwang@vub.ac.be
