Done.
-----Original Message-----
From: Arnulf Christl [mailto:arnulf.christl@ccgis.de]
Sent: Wednesday, September 27, 2006 11:33 AM
To: dev@visibilitycommittee.osgeo.org
Subject: Re: [VisCom] Presentation Templates
Michael P. Gerlek wrote:
> I only did that because (I think?) the CN file system
doesn't support
> versioning.
> Should just make a subdir called "OLD" or something, or
just blow away
> the old version and stop worrying?
late runner up...
"blow away the old version and stop worrying" is the correct
process. We should try to keep the library concise and clean,
it is already hard enough to find the required documents.
There are already documents in other languages makign it even
harder to keep track of what is going on. And there are some
metadata fields that can be used during upload and there is a
status (from draft to archived) that helps orientation.
I have no idea how this library might be managed using the
drupal site. We should start working on that and get rid of
the current thing asap.
Regards, Arnulf.
> -mpg
>> From: Markus Neteler [mailto:neteler.osgeo@gmail.com]
>> Sent: Saturday, September 09, 2006 8:03 AM
>> Thanks.
>> But let me suggest to delete "Presentation Template - v1.opt"
>> (I don't see any sense in keeping it) and rename
>> "Presentation Template - v2" to "Presentation Template".
>> Just one template should be enough.
>> thanks
>> Markus
>> On 9/9/06, Michael P. Gerlek <mpg@lizardtech.com> wrote:
>>> Done. It is buried down in
>> https://visibilitycommittee.osgeo.org/servlets/ProjectDocument
>> List?folde
>>> rID=54 and named "presentation Template - v2".
>>> (I so hate our CN-based library...)
>>> -mpg
>>>> Sent: Wednesday, September 06, 2006 5:01 AM
>>>> Hi Arnulf, mpg,
>>>> I have fixed the (for me) annoying problem that "Times" font was
>>>> predefined in the template. Please update the template in the
>>>> OSGeo library, grab the new file here:
>>>> http://mpa.itc.it/markus/osgeo/
>>>> cheers
>>>> Markus
>>>>>> Yes, that's the right one. Be warned, though, that
>>>> although the design is okay the implementation has issues --
>>>> you'll likely have to tweak the font sizes, indenting,
>>>> bullets, etc, to make things look nice.
>>>>>> -mpg
>>>>> Whatever is tweaked should find its way back to the
>> library. I would
>>>>> like to put that stuff into the VisCom SVN, we even have
>>>> size issues, A4
>>>>> and US-letter and will need to put in some effort to
>> make sure that
>>>>> there are up-to-date versions for all languages. The
>>>> documents & files
>>>>> of the CN structure does not provide enough information
>> and linking
>>>>> possibilities. Sounds like we need to have a VisCom sprint.
>>>> Anybody run
>>>>> for this? Maybe this can be done as an IRC meeting.
>>>>> Regards,
>>>>>> Sent: Mon 9/4/2006 6:36 AM
>>>>>> Subject: [VisCom] Presentation Templates
>>>>>> Hi Michael,
>>>>>> I added a link to the OSGeo template from the VisCom
>>>> library section for
>>>>>> people having a presentation at FOSS4G:
http://wiki.osgeo.org/index.php/OSGeo_at_FOSS4G2006#Talk_Presentations
>>>>>> Could you please confirm that this is the right link?
>>>>>> Thanks a lot,
>>>>>> Arnulf.
>>>>> To unsubscribe, e-mail:
>>>> dev-unsubscribe@visibilitycommittee.osgeo.org
>>>>> For additional commands, e-mail:
>>>> dev-help@visibilitycommittee.osgeo.org
>>>> Open Source Geospatial Foundation
>>>> http://www.osgeo.org/
>> http://grass.osgeo.org/
To unsubscribe, e-mail: dev-unsubscribe@visibilitycommittee.osgeo.org
