While moving containers from osgeo4 (EOL in a couple of days) to osgeo8 I noticed there are two staging containers:
pretalx-staging – is running and does not have nginx configuration
pretalx-staging-2 – has nginx configuration
As we only less than 1T on osgeo8 and its going to be used also for our backups:
I will not restart pretalx-staging
Please confirm that the one you are using for your tests is: pretalx-staging-2
If that is the case, I will remove pretalx-staging and rename pretalx-staging-2 to eliminate the number suffix.
I think pretalx-staging-2 was the one that I had created from production to fix the issue with public voting. I think all of Luca’s efforts to upgrade to PostgreSQL are in the original pretalx-staging.
But lets hold off on deleting either. At a glance it looks like we can expand osgeo8 an extra 1TB. I’ll do that later today.
From: Vicky Vergara vicky@erosion.dev Sent: Friday, March 13, 2026 12:01 PM To: System Administration Committee Discussion/OSGeo sac@lists.osgeo.org Subject: pretalx staging moved to osgeo8
Hi Luca
Looks like pretalx-staging was stopped. I just started it back up. Please give it a try.
The talks.staging.osgeo.org is however pointing at pretalx-staging-2 which is a version after I reapplied the public-voting piece to work in production. Not sure which is easier for you to work with.
-----Original Message-----
Sent: Monday, March 23, 2026 5:00 PM
To: Regina Obe <lr@pcorp.us>
Cc: Vicky Vergara <vicky@erosion.dev>; System Administration Committee
Discussion/OSGeo <sac@lists.osgeo.org>
Subject: Re: pretalx staging moved to osgeo8
Hi Regina, Vicky,
I'm not able to connect to osgeo8-pretalx-staging (instead I'm able to connect
to osgeo8-weblate-staging), should I use another name?
On Mon, 23 Mar 2026 at 22:13, Regina Obe <lr@pcorp.us> wrote:
Luca,
Hi Regina,
I was able to enter, and everything is working fine (also postgresql
db, we need to populate it )
