problem compiling proj.4
Hello Gie,
I am currently trying to install PROJ.4 on our Sun workstation- and hope
to then install mapgen. I am using a script with the following two lines:
sh -x install sun4.1 /usr/local/bin /usr/local/lib /usr/local/include
ranlib /usr/local/lib/libproj.a
I get the following feedback and error messages when I run this script:
----- Begin Included Message -----
+ [ 4 -lt 4 ]
bin=/usr/local/bin
lib=/usr/local/lib
inc=/usr/local/include
+ [ ! -d /usr/local/bin -o ! -w /usr/local/bin ]
+ [ ! -d /usr/local/lib -o ! -w /usr/local/lib ]
+ [ ! -d /usr/local/include -o ! -w /usr/local/include ]
+ cd src
+ make install LIB=/usr/local/lib CC=gcc COMP=-O -DFILENAME_MAX=1024 -DNO_STRERRNO
if [ -f /usr/bin/ranlib -o -f /bin/ranlib ] ; then ranlib libproj.a ; fi
gcc -o proj proj.o gen_cheby.o emess.o libproj.a -lm
ld: -lgcc: No such file or directory
*** Error code 1
make: Fatal error: Command failed for target `proj'
+ [ 1 -ne 0 ]
+ echo make failed
make failed
+ exit 1
ranlib: cannot open /usr/local/lib/libproj.a
----- End Included Message -----
Could you help me identify what the problem is? (also, where can I obtain
the full manual OF-90-284?)
Thank you in advance!
Karen Frederickson
RS/GIS Center
USACRREL
72 Lyme Road
Hanover, NH 03755
(603) 646-4387
