Problem with installation on SGI's
I am having some probelms installing Grass on SG Personal Iris's running
Version 3.3.2 of IRIX.
I am unable to access the databases. I have set up the directories as:
      /u/cipag0/grass
     _______________|_______________
    src bin sgi data src/related etc...
         _______|_______
        spearfish global
        PERMANENT PERMANENT
       _______| _______|
Is this correct for these setup variables:
DEFAULT_DATABASE = /u/cipag0/grass/data
DEFAULT_LOCATION = spearfish
Thank You
David Chatterton
davidc@bruce.cs.monash.edu.au
