Problems with data using V.DIGIT
I once had a similar problem, and it turned out to be "double-lines".
That is to say, they overlapped perfectly....Ouch! You also mentioned
two polygons side-by-side, and this could also be a problem due to
slivers of overlap. These errors are common, I hear, with LULC data.
All I can say is ZOOM, ZOOM, ZOOM....and try not to squint.
Sorry I couldn't be of help.
R. Brian Culpepper Research Assistant
Center for Advanced Spatial Technologies (fax) 501 575-3846
Rm. 214 Ozark Hall (work) 501 575-6159
University of Arkansas brian@cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
Brian Culpepper (brian@cast.uark.edu ) writes on 3 Nov 93:
in which case v.spag may be a big help
