Problems with ftp on moon.cecer.army.mil
Andreas Holz said:
|What about the ls command on moon.cecer.army.mil?. Everytime
|I try a ls, I get the message
| 425 Can't build data connection: Interrupted system service.
     This is a very low-level problem that as of yet has not been solved.
The problem exists for network connections that have long delay times (for
instance, US to Europe). If dir doesn't work, there is a file called ls-lR
in /grass that contains a constantly-updated directory of all the GRASS
archives. If you "cd /grass" and "get ls-lR" you'll have a file that will
help you navigate through the ftp site without the need of the ls command.
     Hope this helps!
|Dipl. Geol. Andreas Holz email: asholz@cip.informatik.uni-erlangen.de
|Institut fuer Geologie und Mineralogie
|Schlossgarten 5
|W-8520 Erlangen
|GERMANY
              Ken.
______________________________________________________________________________
Kenneth R. Brownfield | brownfld@amber.cecer.army.mil |
Office of GRASS Integration, | grass-lists-owner@moon.cecer.army.mil |
United States Army Corps of Engineers | grass-ftp-admin@moon.cecer.army.mil |
Construction Engineering Research | (800) USA-CERL x526 |
Laboratories, Champaign, Illinois | (217) 373-7222 fax |
