|> |> Has anyone successfully printed the GRASS4.0 Programmer's
|> |Manual???<
|I printed the new GRASS 4.0 Programmers Manual on an Apple Personal
|LaserWriter. I experienced the same problem as Richard.
|My output seems perfectly fine until page 83 (start of Chapter 13)
|when the left margin starts to drift as Richard described.
I'm debugging the Postscript as we speak. In the interim, a troff output
format manual is on the moon, and available as I speak. It's in the
doc/4.0.progman directory called progman.troff.Z. This is the troff output
of the manual only, as the postscript index and figures files seem to be
working for everyone. Hopefully the troff version will work for everone.
To print progman.troff issue the following command:
lpr -t progman.troff
Be sure to add any -P or other lpr options that you normally add.
|Teresa Adams
|Civil and Environmental Engineering
|Univ. of Wisconsin-Madison
Ken.
brownfld@enterprise.cecer.army.mil
Kenneth R. Brownfield
