ps.map, hp650c's and paper wasting
Kevin Seel writes:
When I send a postscript plot to our hp650c using ps.map, the printer
happily scrolls our 6 feet or so of expensive paper before it decides
to print something. Does anybody have an idea why it does this, and
how I can get around it?
I know - we get the same thing with our HP. Similarly, our xerox versetec type
with special software seems to think everything is letter size. This occurs
with several conversion programs, so it's not endemic to ps.map.
The best I have heard so far is that the postscript file is not produced with
a fixed size - I do not know if this is true.
However - I thought (am not sure) that this only occurs if the plotter is in
HPGL mode and is sent the language conversion command. Is your plotter set
to default to HGL or to postscript?
mzk
