ps.map - linux
Hi Anthony
On Jan 27, 12:26pm, anthony burns wrote:
Subject: ps.map - linux
Linux grass users
I ps.select the printer driver ie hp650D, a3 or whatever, it accepts it just
fine. I then use ps.map to develop the map. After I respond to all questions
and give a file name to output the map, the process begins , I see ps.map
select
the printer and then it immediately core dumps with a segmentation fault.
Any ideas as to what the problem is.
Thanks
Anthony
-- End of excerpt from anthony burns
You may want to try the bug fix on the GRASS FAQ page
(http://www.cecer.army.mil/grass/faq.html), question 12 - there is a fix for
the ps.select command. Although the bug caused different results (the command
quit with an error message - no core dump) on our system, your problem may be
the same bug.
Hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
