Buongiorno,
appena ho caricato un progetto di prova creato con la versione “Firenze” contenente shp creati in parte con QAD ho ottenuto ripetutamente il seguente errore, per cui ora ritornerò a Firenze.
Cordiali saluti e buon lavoro.
Giovanni
An error has occurred while executing Python code:
AttributeError: ‘QadMapTool’ object has no attribute ‘_QadMapTool__csrRubberBand’
File “C:\Users/giova/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qad\qad_maptool.py”, line 234, in canvasMoveEvent
self.__csrRubberBand.moveEvent(point)
Python version: 3.9.18 (heads/master:5eba59e, Feb 1 2024, 20:02:10) [MSC v.1929 64 bit (AMD64)]
QGIS version: 3.34.4-Prizren Prizren, decd43dc
Python Path:
C:/PROGRA~1/QGIS33~1.4/apps/qgis-ltr/./python
C:/Users/giova/AppData/Roaming/QGIS/QGIS3\profiles\default/python
C:/Users/giova/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
C:/PROGRA~1/QGIS33~1.4/apps/qgis-ltr/./python/plugins
C:\PROGRA~1\QGIS33~1.4\apps\grass\grass83\etc\python
C:\Users\giova\Documents
C:\Program Files\QGIS 3.34.4\bin\python39.zip
C:\PROGRA~1\QGIS33~1.4\apps\Python39\DLLs
C:\PROGRA~1\QGIS33~1.4\apps\Python39\lib
C:\PROGRA~1\QGIS33~1.4\apps\Python39\lib\site-packages
C:\PROGRA~1\QGIS33~1.4\apps\Python39\lib\site-packages\win32
C:\PROGRA~1\QGIS33~1.4\apps\Python39\lib\site-packages\win32\lib
C:\PROGRA~1\QGIS33~1.4\apps\Python39\lib\site-packages\Pythonwin
C:\Users\giova\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\kmltools\libs
G:/comune_e266u1_master/sviluppo_prof_master/QGIS_totale/addestramento/Gis3
