Buona sera a tutt*
dopo aggiornamento tramite osgeo su win10 64bit, all’avvio QGIS 3.4 o 3.10 LTR non mi carica il plugin processing e trovo il seguente log
Avete un suggerimento?
grazie
2020-02-03T19:52:55 WARNING warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_proj_helper.py:8: DeprecationWarning: QgsCoordinateReferenceSystem constructor is deprecated
CRS_3857 = QgsCoordinateReferenceSystem(3857)
traceback: File “”, line 1, in
File “C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py”, line 354, in startPlugin
if not _startPlugin(packageName):
File “C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py”, line 334, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services_init.py", line 34, in classFactory
from .quick_map_services import QuickMapServices
File “C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py”, line 744, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in _load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in _call_with_frames_removed
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\quick_map_services.py”, line 40, in
from .qgis_map_helpers import add_layer_to_map
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_map_helpers.py”, line 17, in
from .py_tiled_layer.tilelayer import TileLayer
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\py_tiled_layer\tilelayer.py”, line 36, in
from …qgis_proj_helper import ProjectionHelper
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_proj_helper.py”, line 7, in
class ProjectionHelper:
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_proj_helper.py”, line 8, in ProjectionHelper
2020-02-03T19:52:55 WARNING warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\py_tiled_layer\tilelayer.py:64: DeprecationWarning: QgsCoordinateReferenceSystem constructor is deprecated
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\py_tiled_layer\tilelayer.py”, line 62, in
class TileLayer(QgsPluginLayer):
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\py_tiled_layer\tilelayer.py”, line 64, in TileLayer
2020-02-03T19:52:55 WARNING warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\rb_result_renderer.py:35: DeprecationWarning: QgsCoordinateReferenceSystem constructor is deprecated
self.srs_wgs84 = QgsCoordinateReferenceSystem(4326)
File “C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py”, line 359, in startPlugin
plugins[packageName].initGui()
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\quick_map_services.py”, line 121, in initGui
self.init_server_panel()
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\quick_map_services.py”, line 311, in init_server_panel
self.server_toolbox = QmsServiceToolbox(self.iface)
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qms_service_toolbox.py”, line 135, in init
self.extent_renderer = RubberBandResultRenderer()
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\rb_result_renderer.py”, line 35, in init
2020-02-03T19:52:56 WARNING warning:C:\OSGEO4~1\apps\Python37\lib\site-packages\urllib3\connectionpool.py:1004: InsecureRequestWarning: Unverified HTTPS request is being made to host ‘qms.nextgis.com’. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
InsecureRequestWarning,
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qms_service_toolbox.py”, line 155, in init
self.show_news()
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qms_service_toolbox.py”, line 160, in show_news
qms_news = client.get_news()
File “C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qms_external_api_python\api\api_abstract.py”, line 64, in get_news
response = get(url, verify=False)
File “C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\api.py”, line 75, in get
return request(‘get’, url, params=params, **kwargs)
File “C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\api.py”, line 60, in request
return session.request(method=method, url=url, **kwargs)
File “C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\adapters.py”, line 449, in send
timeout=timeout
File “C:\OSGEO4~1\apps\Python37\lib\site-packages\urllib3\connectionpool.py”, line 672, in urlopen
chunked=chunked,
File “C:\OSGEO4~1\apps\Python37\lib\site-packages\urllib3\connectionpool.py”, line 376, in _make_request
self._validate_conn(conn)
File “C:\OSGEO4~1\apps\Python37\lib\site-packages\urllib3\connectionpool.py”, line 1004, in _validate_conn
Alberto
Il giorno lun 3 feb 2020 alle ore 18:53 Paolo Cavallini <cavallini@faunalia.it> ha scritto:
capito, in effetti strano che non ci sia fra le opzioni dell’alg nativo,
puoi aprire una feature request per cortesia?
grazie
Il 03/02/20 09:20, Luca Puglisi ha scritto:
Buffer di una linea con estremi piatti, diciamo tronchi, anziche’
stondati (tipo endcap=flat)
grazie, ciao
Luca
Il 03/02/2020 08:40, Paolo Cavallini ha scritto:
in che senso squadrati?
saluti.
Il 03/02/20 08:28, Luca Puglisi ha scritto:
Nell’occasione semplicemente quello per fare buffer, avendo la
necessita’ di farli squadrati–
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
QGIS-it-user mailing list
QGIS-it-user@lists.osgeo.org
QGIS.ORG Chair:
