errori con python 3.6 e qgis 3 , qualche altro ha avuto lo stesso problema??
grazie
Impossibile caricare il plugin 'ImportPhotos' a causa di un errore chiamando
il metodo classFactory()
ModuleNotFoundError: No module named 'exifread'
File
"/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py",
line 336, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "/Users/Harlock/Library/Application
Support/QGIS/QGIS3/profiles/default/python/plugins/ImportPhotos/__init__.py",
line 32, in classFactory
from .ImportPhotos import ImportPhotos
File
line 664, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
Support/QGIS/QGIS3/profiles/default/python/plugins/ImportPhotos/ImportPhotos.py",
line 33, in
from .MouseClick import MouseClick
File
Support/QGIS/QGIS3/profiles/default/python/plugins/ImportPhotos/MouseClick.py",
line 31, in
import exifread
File
Versione Python: 3.6.4 (v3.6.4:d48ecebad5, Dec 18 2017, 21:07:28) [GCC 4.2.1
(Apple Inc. build 5666) (dot 3)]
Versione di QGIS: 3.0.0-Girona Girona, exported
Percorso Python:
/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins
/Library/Frameworks/GEOS.framework/Versions/3B/Python/3.6/site-packages
/Library/Frameworks/GDAL.framework/Versions/2.2/Python/3.6/site-packages
/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
