Carissimi,
sto riscontrando diversi problemi ad installare QGIS Server 3.4 su un server con ubuntu 16 xenial.
Ho aggiunto i seguenti repository a /etc/apt/sources.list
deb http://qgis.org/ubuntugis-ltr xenial main
deb-src http://qgis.org/ubuntugis-ltr xenial main
Con questi aggiunti, col comando apt-cache policy qgis-server mi individua correttamente la versione 3.4.5+24xenial-ubuntugis
ma quando gli dico di installare mi lascia questi errori
apt-get -y install qgis-server python-qgis
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python-qgis : Depends: python-qgis-common (= 1:3.4.5+24xenial-ubuntugis) but it is not going to be installed
Depends: libqgispython3.4.5 but it is not going to be installed
Depends: libqgis-analysis3.4.5 but it is not going to be installed
Depends: libqgis-core3.4.5 but it is not going to be installed
Depends: libqgis-gui3.4.5 but it is not going to be installed
Depends: libqgis-server3.4.5 but it is not going to be installed
qgis-server : Depends: qgis-providers (= 1:3.4.5+24xenial-ubuntugis) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Ho provato ad installare manualmente ma non le trova, gli stessi errori li ho anche se provo ad installare qgis.
Qualcuno ha sperimentato gli stessi errori?
Ho fatto la stessa installazione anche su un server ubuntu 18 bionic ed è filata liscissima, purtoppo non posso fare l’upgrade di ubuntu 16.
Grazie mille
Federico
