Buonasera,
per favore sapete perché non riesco a installare il plugin Qweet, che vorrei utilizzare per analizzare flussi di informazioni di Twitter?
Il plugin richiede l'installazione di una library che si chiama tweepy. Cosa che ho fatto, ma questo è il messaggio che mi rimanda Qgis (versione 3.12.0-București):
Grazie e saluti
Gabriele Di Palma
Could not import tweepy, install tweepy to use the plugin
Impossibile caricare il plugin 'qweetgis' a causa di un errore chiamando il metodo classFactory()
ModuleNotFoundError: No module named 'tweepy'
File "/Applications/QGIS3.12.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 334, in _startPlugin
plugins[packageName] = package.classFactory(iface)
File "/Users/alekseyvoda/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/qweetgis/__init__.py", line 35, in classFactory
from .search.main import ThreadingMaster
File "/Applications/QGIS3.12.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 744, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/Users/alekseyvoda/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/qweetgis/search/main.py", line 48, in
from ..authentication.credentials_validator import CredentialsValidator
File "/Users/alekseyvoda/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/qweetgis/authentication/credentials_validator.py", line 3, in
from ..authentication.mod_tweepy import TestTweetsAuthHandler
File "/Users/alekseyvoda/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/qweetgis/authentication/mod_tweepy.py", line 3, in
import tweepy
Versione Python: 3.7.3 (default, Mar 27 2019, 09:23:15) [Clang 10.0.1 (clang-1001.0.46.3)]
Versione di QGIS: 3.12.0-București București, 409bcf8eaa
Percorso Python:
/Applications/QGIS3.12.app/Contents/MacOS/../Resources/python/plugins
/Applications/QGIS3.12.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages
/Applications/QGIS3.12.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python37.zip
/Applications/QGIS3.12.app/Contents/Resources/python
/Applications/QGIS3.12.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages/geos
/Applications/QGIS3.12.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/lib-dynload
