FYI su Sptalialite
-------- Forwarded Message --------
Subject: Re: [QGIS-Developer] QGIS and spatialite
Date: Mon, 18 May 2020 14:38:05 +0200
To: qgis-developer@lists.osgeo.org
Andreas,
I am struggling with libspatialite. What libspatialite versions are you
guys using? I am trying to compile libspatialite-4.3.0a, but it
complains about not finding "proj_api.h" (although this file is
available at /usr/local/include). I tried both with proj-6.3.2 and
proj-7.0.1. libspatialite-4.3.0a isn't happy with either proj version.
For 4.3.0a:
CFLAGS="-DACCEPT_USE_OF_DEPRECATED_PROJ_API_H -O2 should help:
https://github.com/OSGeo/gdal/blob/master/gdal/docker/alpine-normal/Dockerfile#L248
You can also build against the development repository of Spatialite:
https://github.com/OSGeo/gdal/blob/master/gdal/ci/travis/ubuntu_1804/install.sh#L27
(you could probably drop the "fossil update 90180e065d" which must have
been a
workaround against a regression, and the other peculiarities), so mostly:
fossil clone https://www.gaia-gis.it/fossil/libspatialite
libspatialite.fossil
mkdir sl
cd sl
fossil open ../libspatialite.fossil
./configure [...]
I noticed that there
hadn't been a lot of activity with this library in the past months/years.
Yes, I've tried to maintain a communication channel with the developper,
but with
moderate success only. The development is not abandoned, but only at a
rather slow
pace.
On a related question: could I build QGIS without libspatialite? I
failed to do so, but maybe there are some tricks.
I don't think you can without some surgery in the code base.
FWIW, the WFS provider depends on it for caching (could potentially be
replaced by
something else)
Even
Spatialys - Geospatial professional services
