Ciao, sto facendo alcuni test sul nuovo tool da riga di comando,
uso ubuntu 18.04
qgis 3.14.1
gdal 2.2.3
lanciando il comando randompointsinsidepolygons, dove i parametri sono:
Arguments
INPUT: Input layer
Argument type: source
Acceptable values:
- Path to a vector layer
STRATEGY: Sampling strategy
Argument type: enum
Available values:
- 0: Points count
- 1: Points density
Acceptable values:
- Number of selected option, e.g. '1'
- Comma separated list of options, e.g. '1,3'
VALUE: Point count or density
Argument type: number
Acceptable values:
- A numeric value
MIN_DISTANCE: Minimum distance between points
Argument type: distance
Acceptable values:
- A numeric value
OUTPUT: Random points
Argument type: sink
Acceptable values:
- Path for new vector layer
ottengo questo errore:
pigreco@lenovo:/mnt/c/Users/pigre/Desktop/Limiti01012020_g$ qgis_process run
qgis:randompointsinsidepolygons --STRATEGY=0 --VALUE=1000
--INPUT="./ProvCM01012020_g/ProvCM01012020_g_WGS84.shp"
--OUTPUT="./output/random_point_prov.shp"
/usr/lib/python3/dist-packages/qgis/utils.py:743: DeprecationWarning: the
imp module is deprecated in favour of importlib; see the module's
documentation for alternative uses
mod = _builtin_import(name, globals, locals, fromlist, level)
Problem with SAGA installation: SAGA was not found or is not correctly
installed
Inputs
INPUT: ./ProvCM01012020_g/ProvCM01012020_g_WGS84.shp
OUTPUT: ./output/random_point_prov.shp
STRATEGY: 0
VALUE: 1000
Logged critical: Traceback (most recent call last):
File
"/usr/share/qgis/python/plugins/processing/algs/qgis/RandomPointsPolygons.py",
line 160, in processAlgorithm
da.setEllipsoid(context.project().ellipsoid())
AttributeError: 'NoneType' object has no attribute 'ellipsoid'
File
ERROR: Traceback (most recent call last):
File
è normale??
saluti
https://pigrecoinfinito.wordpress.com/
